How to render polygons with an animated water texture?
Hi there,
I’m loading some geoJSON data and would like to symbolize the data with an animated water material. When I run this code below, all I see is a white polygon. Am I missing something?
promise.then(function(dataSource) {
            for (var i = 0; i < entities.length; i++) {
                var entity = entities[i];
                    entity.polygon.outline = false;
/* 				entity.polygon.material = new Cesium.ImageMaterialProperty({
						image: 'water.jpg',
						alpha: 0.1
                entity.polygon.material = new Cesium.Material({
				fabric: {
				  type: "Water",
				  uniforms: {
					normalMap: "water.jpg",
					frequency: 10000.0,
					animationSpeed: 0.01,
					amplitude: 1.0,
Thanks in advance,
Mapper
PS I have also noticed when adding a color material:
			entity.polygon.material = new Cesium.ColorTypeMaterial({
			  fabric: {
				type: 'Color',
				uniforms: {
				  color: new Cesium.Color(1.0, 1.0, 0.0, 1.0)
Polygons are also rendered white. It seems this code is getting ignored?
Ah, this is not supported for entities:
Which is sad :frowning:
