How to set the camera postion into underground area
Hi, I have a question about setting/moving the camera into underground area. Since some 3dtiles that my colleagues made are underground models. I need a method to view them. Thanks for help.
No code yet.
As decribed before.
version 1.52
Underground support is something that’s been on our radar for a long time, check out this experimental PR that attempts to add support for it:
https://github.com/AnalyticalGraphicsInc/cesium/pull/6047
There seems to be a fair bit of issues to resolve to get that to fully work. If you’re just concerned about the camera, I wonder if just turning off the terrain adjustment/collision check will do the trick. This PR attempts to make that configurable:
https://github.com/AnalyticalGraphicsInc/cesium/pull/6012
Let me know if that helps! I’m definitely curious to hear if you’re able to get this to work successfully.
