Dear sir,
I have a issue here.
How can i access name for related coordinates.
I have to change color of pinters based on name too. Example of geojson file.
Right now only option i have is javascript to match name and find coordinates. This does not seems correct way.
"type": "Feature",
"geometry": {
"type": "LineString",
"coordinates": [
-11.19,
53.36,
0
-11.54,
53.43,
0
"properties": {
"name": "D-ABVY - Offline",
"styleUrl": "#OfflineSegment_HISTORY",
"styleHash": "-3d628f72",
"description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:30:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:32:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.250dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.004dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>693.917s</td></tr>\n <tr><td><i>Jitter:</i></td><td>1.637</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.170dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.777dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>688.877s</td></tr>\n <tr><td><i>Jitter:</i></td><td>48.963</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [
-9.12,
52.95,
0
"properties": {
"name": "D-ABVY - Logoff",
"styleUrl": "#LOGOFF",
"styleHash": "-12805470",
"description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:41:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.865dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>690.627s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.103</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
"type": "Feature",
"geometry": {
"type": "Point",
"coordinates": [
-8.66,
52.85,
0
"properties": {
"name": "D-ABVY - Login",
"styleUrl": "#LOGIN",
"styleHash": "69949246",
"description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:43:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.017dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>676.346s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
"type": "Feature",
"geometry": {
"coordinates": [
-8.66,
52.85,
0
-9.12,
52.95,
0
"properties": {
"description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:41:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:43:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.865dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>690.627s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.103</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.017dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>676.346s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
Thanks
