geojson - how to access the coordinates
I am new to cesiumjs.
I have 2 questions-
1. I have a KML file which I am converting into geojson on run time.
Here is example of file (Below). I would like to access the coordinates from this file, but could not figure out and found nothing which can help.
var dataSource = new Cesium.GeoJsonDataSource();
dataSource.loadUrl('SampleData/kml_2_geo_json_kml.geojson',{
stroke: Cesium.Color.RED,
fill: Cesium.Color.PINK,
strokeWidth: 10,
markerSymbol: 'airport', //'?',
//markerColor : Cesium.Color.GREEN,
markerSize: 0
).then(function() {
for (var i = 0; i < entities.length; i++) {
        var entity = entities[i];
        var name = entity.name;
In entity object I never get this part
"type": "Feature",
            "geometry": {
                "type": "LineString",
                "coordinates": [
                        -57.7895,
                        50.2805,
                        0
                        -57.5795,
                        50.3405,
                        0
2. Another question is – My geojson data belongs to the flight data and I want to create pointers on departure and landing points. This part I can do with Entity API but will it make my code slow ?
My geojson example -
    "type": "FeatureCollection",
    "features": [
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -78.9495,
                        43.7005,
                        0
                        -78.8095,
                        43.7505,
                        0
                        -78.6495,
                        43.8105,
                        0
                        -78.4895,
                        43.8605,
                        0
                        -78.3295,
                        43.9205,
                        0
                        -78.1495,
                        43.9805,
                        0
                        -77.9795,
                        44.0405,
                        0
                        -77.7895,
                        44.1005,
                        0
                        -77.6095,
                        44.1605,
                        0
                        -77.4395,
                        44.2305,
                        0
                        -77.2695,
                        44.3105,
                        0
                        -77.0895,
                        44.3805,
                        0
                        -76.9195,
                        44.4605,
                        0
                        -76.7495,
                        44.5405,
                        0
                        -76.5695,
                        44.6105,
                        0
                        -76.3995,
                        44.6905,
                        0
                        -76.1195,
                        44.7905,
                        0
                        -76.0295,
                        44.8205,
                        0
                        -75.8295,
                        44.8705,
                        0
                        -75.6295,
                        44.9205,
                        0
                        -75.4395,
                        44.9705,
                        0
                        -75.2395,
                        45.0205,
                        0
                        -75.0395,
                        45.0705,
                        0
                        -74.8395,
                        45.1205,
                        0
                        -74.6395,
                        45.1705,
                        0
                        -74.4395,
                        45.2305,
                        0
                        -74.2395,
                        45.2805,
                        0
                        -74.0495,
                        45.3405,
                        0
                        -73.8495,
                        45.4005,
                        0
                        -73.6595,
                        45.4705,
                        0
                        -73.4695,
                        45.5305,
                        0
                        -73.2695,
                        45.6005,
                        0
                        -73.0795,
                        45.6605,
                        0
                        -72.8895,
                        45.7305,
                        0
                        -72.6895,
                        45.7905,
                        0
                        -72.4995,
                        45.8605,
                        0
                        -72.2995,
                        45.9205,
                        0
                        -72.0995,
                        45.9805,
                        0
                        -71.9095,
                        46.0505,
                        0
                        -71.7095,
                        46.1105,
                        0
                        -71.5095,
                        46.1705,
                        0
                        -71.3095,
                        46.2305,
                        0
                        -71.1095,
                        46.3005,
                        0
                        -70.9095,
                        46.3605,
                        0
                        -70.7095,
                        46.4205,
                        0
                        -70.5095,
                        46.4805,
                        0
                        -70.2995,
                        46.5405,
                        0
                        -70.0995,
                        46.6005,
                        0
                        -69.8995,
                        46.6605,
                        0
                        -69.6995,
                        46.7205,
                        0
                        -69.4995,
                        46.7805,
                        0
                        -69.2995,
                        46.8305,
                        0
                        -69.0895,
                        46.8905,
                        0
                        -68.8895,
                        46.9505,
                        0
                        -68.7895,
                        46.9805,
                        0
                        -68.4795,
                        47.0605,
                        0
                        -68.2695,
                        47.1205,
                        0
                        -68.0695,
                        47.1705,
                        0
                        -67.8595,
                        47.2305,
                        0
                        -67.6595,
                        47.2805,
                        0
                        -67.4495,
                        47.3405,
                        0
                        -67.2495,
                        47.4005,
                        0
                        -67.0595,
                        47.4805,
                        0
                        -66.8695,
                        47.5605,
                        0
                        -66.6795,
                        47.6405,
                        0
                        -66.4895,
                        47.7205,
                        0
                        -66.2995,
                        47.8005,
                        0
                        -66.1095,
                        47.8805,
                        0
                        -65.9195,
                        47.9605,
                        0
                        -65.7295,
                        48.0405,
                        0
            "properties": {
                "name": "D-ABVY - LH471 - FINAL Aug-26 23:09",
                "styleUrl": "#AIRPLANE_FLIGHT_PATH_D-ABVY_2015_08_26_23_09_00",
                "styleHash": "3e267478",
                "description": "\n \n <table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n </table>\n <b>Beam Information:</b>\n <table>\n <tr><td><i>Beam ID:</i></td><td>1</td></tr>\n <tr><td><i>Beam Name:</i></td><td>G17</td></tr>\n </table>\n <p><i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i></p>\n <p><a href=\"http://flightfeed.panasonic.aero/All/HistoryFlight.php?FlightID=1051876\">more...</a></p>\n <p><a href=\"https://swa-wiki.mascorp.com/bin/view/SWA/FFPPT\">FlightFeed Wiki</a></p>\n \n ",
                "stroke": "#55CC88",
                "stroke-opacity": 1,
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -65.1195,
                        48.2705,
                        0
                        -65.0195,
                        48.3005,
                        0
                        -64.8195,
                        48.3605,
                        0
                        -64.6095,
                        48.4205,
                        0
                        -64.4095,
                        48.4805,
                        0
                        -64.2095,
                        48.5405,
                        0
                        -64.0095,
                        48.6005,
                        0
                        -63.7995,
                        48.6605,
                        0
                        -63.5995,
                        48.7205,
                        0
                        -63.2895,
                        48.8105,
                        0
                        -63.0895,
                        48.8705,
                        0
                        -62.9795,
                        48.9005,
                        0
                        -62.6695,
                        48.9905,
                        0
                        -62.5695,
                        49.0205,
                        0
                        -62.3595,
                        49.0805,
                        0
                        -62.1495,
                        49.1305,
                        0
                        -61.9495,
                        49.1905,
                        0
                        -61.7395,
                        49.2505,
                        0
                        -61.5295,
                        49.3005,
                        0
                        -61.3195,
                        49.3605,
                        0
                        -61.1095,
                        49.4105,
                        0
                        -60.8995,
                        49.4705,
                        0
                        -60.5895,
                        49.5505,
                        0
                        -60.4895,
                        49.5805,
                        0
                        -60.2795,
                        49.6305,
                        0
                        -60.0695,
                        49.6805,
                        0
                        -59.8695,
                        49.7405,
                        0
                        -59.6595,
                        49.7905,
                        0
            "properties": {
                "description": "\n \n <table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n </table>\n <b>Beam Information:</b>\n <table>\n <tr><td><i>Beam ID:</i></td><td>89</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n </table>\n <p><i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i></p>\n <p><a href=\"http://flightfeed.panasonic.aero/All/HistoryFlight.php?FlightID=1051876\">more...</a></p>\n <p><a href=\"https://swa-wiki.mascorp.com/bin/view/SWA/FFPPT\">FlightFeed Wiki</a></p>\n \n ",
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -59.1295,
                        49.9205,
                        0
                        -59.0295,
                        49.9405,
                        0
                        -58.7195,
                        50.0305,
                        0
                        -58.6195,
                        50.0605,
                        0
                        -58.3095,
                        50.1505,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -58.1995,
                        50.1705,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -57.7895,
                        50.2805,
                        0
                        -57.5795,
                        50.3405,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -57.0595,
                        50.4705,
                        0
                        -56.9595,
                        50.5005,
                        0
                        -56.7495,
                        50.5505,
                        0
                        -56.5395,
                        50.6105,
                        0
                        -56.3395,
                        50.6605,
                        0
                        -56.1295,
                        50.7105,
                        0
                        -55.8195,
                        50.7805,
                        0
                        -55.7095,
                        50.8105,
                        0
                        -55.4995,
                        50.8605,
                        0
                        -55.2995,
                        50.9105,
                        0
                        -55.0895,
                        50.9605,
                        0
                        -54.8895,
                        51.0105,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -54.4795,
                        51.1005,
                        0
                        -54.2695,
                        51.1505,
                        0
                        -54.0595,
                        51.1905,
                        0
                        -53.8595,
                        51.2405,
                        0
                        -53.6495,
                        51.2805,
                        0
                        -53.4395,
                        51.3305,
                        0
                        -53.1195,
                        51.4005,
                        0
                        -53.0195,
                        51.4205,
                        0
                        -52.8095,
                        51.4605,
                        0
                        -52.5995,
                        51.5005,
                        0
                        -52.3895,
                        51.5505,
                        0
                        -52.1795,
                        51.5905,
                        0
                        -51.9695,
                        51.6305,
                        0
                        -51.7595,
                        51.6705,
                        0
                        -51.5395,
                        51.7205,
                        0
                        -51.3295,
                        51.7605,
                        0
                        -51.1195,
                        51.8005,
                        0
                        -50.9095,
                        51.8405,
                        0
                        -50.5895,
                        51.8905,
                        0
                        -50.4795,
                        51.9105,
                        0
                        -50.2695,
                        51.9505,
                        0
                        -50.0595,
                        51.9905,
                        0
                        -49.8395,
                        52.0205,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -49.1895,
                        52.1105,
                        0
                        -48.9695,
                        52.1405,
                        0
                        -48.7495,
                        52.1705,
                        0
                        -48.5295,
                        52.2005,
                        0
                        -48.3095,
                        52.2305,
                        0
                        -48.0895,
                        52.2505,
                        0
                        -47.8795,
                        52.2805,
                        0
                        -47.6595,
                        52.3105,
                        0
                        -47.4295,
                        52.3305,
                        0
                        -47.2095,
                        52.3605,
                        0
                        -46.9895,
                        52.3905,
                        0
                        -46.6595,
                        52.4205,
                        0
                        -46.5495,
                        52.4405,
                        0
                        -46.3195,
                        52.4605,
                        0
                        -46.0995,
                        52.4905,
                        0
                        -45.8695,
                        52.5105,
                        0
                        -45.6495,
                        52.5305,
                        0
                        -45.4195,
                        52.5605,
                        0
                        -45.1995,
                        52.5805,
                        0
                        -44.9695,
                        52.6005,
                        0
                        -44.7495,
                        52.6205,
                        0
                        -44.5295,
                        52.6405,
                        0
                        -44.2995,
                        52.6705,
                        0
                        -44.0795,
                        52.6905,
                        0
                        -43.7395,
                        52.7205,
                        0
                        -43.6295,
                        52.7305,
                        0
                        -43.3995,
                        52.7505,
                        0
                        -43.1795,
                        52.7705,
                        0
                        -42.9495,
                        52.7805,
                        0
                        -42.7195,
                        52.8005,
                        0
                        -42.3795,
                        52.8305,
                        0
                        -42.2595,
                        52.8405,
                        0
                        -42.0295,
                        52.8605,
                        0
                        -41.8095,
                        52.8705,
                        0
                        -41.5795,
                        52.8905,
                        0
                        -41.3495,
                        52.9105,
                        0
                        -41.1195,
                        52.9205,
                        0
                        -40.7695,
                        52.9505,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -40.4195,
                        52.9705,
                        0
                        -40.0795,
                        52.9905,
                        0
                        -39.9595,
                        53.0005,
                        0
                        -39.7195,
                        53.0005,
                        0
                        -39.4895,
                        53.0105,
                        0
                        -39.2395,
                        53.0205,
                        0
                        -38.9995,
                        53.0305,
                        0
                        -38.7595,
                        53.0405,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -38.1595,
                        53.0605,
                        0
                        -38.0395,
                        53.0605,
                        0
                        -37.6795,
                        53.0705,
                        0
                        -37.5595,
                        53.0805,
                        0
                        -37.3295,
                        53.0805,
                        0
                        -37.0995,
                        53.0905,
                        0
                        -36.8595,
                        53.0905,
                        0
                        -36.6295,
                        53.1005,
                        0
                        -36.3995,
                        53.1005,
                        0
                        -36.1695,
                        53.1005,
                        0
                        -35.9395,
                        53.1005,
                        0
                        -35.7095,
                        53.1105,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -35.2395,
                        53.1105,
                        0
                        -35.0095,
                        53.1105,
                        0
                        -34.7695,
                        53.1105,
                        0
                        -34.5395,
                        53.1105,
                        0
                        -34.3095,
                        53.1105,
                        0
                        -34.0695,
                        53.1105,
                        0
                        -33.8395,
                        53.1005,
                        0
                        -33.5995,
                        53.1005,
                        0
                        -33.3695,
                        53.1005,
                        0
                        -33.0095,
                        53.0905,
                        0
                        -32.8995,
                        53.0905,
                        0
                        -32.5395,
                        53.0805,
                        0
                        -32.4295,
                        53.0805,
                        0
                        -32.1895,
                        53.0805,
                        0
                        -31.9595,
                        53.0705,
                        0
                        -31.5995,
                        53.0605,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -31.2495,
                        53.0505,
                        0
                        -31.0195,
                        53.0405,
                        0
                        -30.7795,
                        53.0305,
                        0
                        -30.5495,
                        53.0205,
                        0
                        -30.3095,
                        53.0105,
                        0
                        -30.0795,
                        53.0005,
                        0
                        -29.8495,
                        53.0205,
                        0
                        -29.6195,
                        53.0605,
                        0
                        -29.3895,
                        53.0905,
                        0
                        -29.1595,
                        53.1205,
                        0
                        -28.9295,
                        53.1505,
                        0
                        -28.6995,
                        53.1805,
                        0
                        -28.4695,
                        53.2105,
                        0
                        -28.2395,
                        53.2405,
                        0
                        -28.0095,
                        53.2705,
                        0
                        -27.7795,
                        53.3005,
                        0
                        -27.5395,
                        53.3205,
                        0
                        -27.3095,
                        53.3505,
                        0
                        -27.0795,
                        53.3805,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -26.4995,
                        53.4405,
                        0
                        -26.3795,
                        53.4605,
                        0
                        -26.1495,
                        53.4805,
                        0
                        -25.9195,
                        53.5105,
                        0
                        -25.6895,
                        53.5305,
                        0
                        -25.4495,
                        53.5605,
                        0
                        -25.2195,
                        53.5805,
                        0
                        -24.9795,
                        53.6005,
                        0
                        -24.7495,
                        53.6305,
                        0
                        -24.5095,
                        53.6505,
                        0
                        -24.1495,
                        53.6805,
                        0
                        -24.0395,
                        53.6905,
                        0
                        -23.7995,
                        53.7105,
                        0
                        -23.5595,
                        53.7405,
                        0
                        -23.3195,
                        53.7605,
                        0
                        -23.0895,
                        53.7805,
                        0
                        -22.8495,
                        53.8005,
                        0
                        -22.6095,
                        53.8105,
                        0
                        -22.2595,
                        53.8405,
                        0
                        -22.1395,
                        53.8505,
                        0
                        -21.8995,
                        53.8705,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -21.2995,
                        53.9105,
                        0
                        -21.1795,
                        53.9205,
                        0
                        -20.9395,
                        53.9405,
                        0
                        -20.6995,
                        53.9505,
                        0
                        -20.4595,
                        53.9705,
                        0
                        -20.2295,
                        53.9805,
                        0
                        -19.9895,
                        54.0005,
                        0
                        -19.7395,
                        54.0005,
                        0
                        -19.4995,
                        54.0105,
                        0
                        -19.2595,
                        54.0105,
                        0
                        -19.0195,
                        54.0105,
                        0
                        -18.6495,
                        54.0205,
                        0
                        -18.5295,
                        54.0205,
                        0
                        -18.2895,
                        54.0205,
                        0
                        -18.0495,
                        54.0305,
                        0
                        -17.8095,
                        54.0305,
                        0
                        -17.5695,
                        54.0305,
                        0
                        -17.3195,
                        54.0305,
                        0
                        -17.0795,
                        54.0305,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -16.5995,
                        54.0305,
                        0
                        -16.3595,
                        54.0305,
                        0
                        -16.1095,
                        54.0205,
                        0
                        -15.8695,
                        54.0205,
                        0
                        -15.6295,
                        54.0205,
                        0
                        -15.3795,
                        54.0105,
                        0
                        -15.1395,
                        54.0105,
                        0
                        -14.8995,
                        53.9905,
                        0
                        -14.6595,
                        53.9605,
                        0
                        -14.4295,
                        53.9205,
                        0
                        -14.1995,
                        53.8805,
                        0
                        -13.9595,
                        53.8505,
                        0
                        -13.7295,
                        53.8105,
                        0
                        -13.4995,
                        53.7705,
                        0
                        -13.2695,
                        53.7305,
                        0
                        -13.0395,
                        53.6905,
                        0
                        -12.6895,
                        53.6305,
                        0
                        -12.5695,
                        53.6105,
                        0
                        -12.3395,
                        53.5705,
                        0
                        -12.1095,
                        53.5305,
                        0
                        -11.7695,
                        53.4705,
                        0
                        -11.5395,
                        53.4305,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -11.1895,
                        53.3605,
                        0
                        -10.9595,
                        53.3205,
                        0
                        -10.7295,
                        53.2805,
                        0
                        -10.4995,
                        53.2305,
                        0
                        -10.2695,
                        53.1805,
                        0
                        -10.0395,
                        53.1405,
                        0
                        -9.8095,
                        53.0905,
                        0
                        -9.5795,
                        53.0405,
                        0
                        -9.3495,
                        53.0005,
                        0
                        -9.1195,
                        52.9505,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -8.6595,
                        52.8505,
                        0
            "properties": {
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -6.8595,
                        52.4405,
                        0
                        -6.6395,
                        52.3905,
                        0
                        -6.4095,
                        52.3305,
                        0
                        -6.1795,
                        52.2805,
                        0
                        -5.9595,
                        52.2205,
                        0
                        -5.7295,
                        52.1705,
                        0
                        -5.5095,
                        52.1205,
                        0
                        -5.2595,
                        52.1005,
                        0
                        -5.0095,
                        52.0805,
                        0
                        -4.7695,
                        52.0505,
                        0
                        -4.5195,
                        52.0305,
                        0
                        -4.2795,
                        52.0005,
                        0
                        -4.0295,
                        51.9705,
                        0
                        -3.7795,
                        51.9405,
                        0
                        -3.5395,
                        51.9205,
                        0
                        -3.2895,
                        51.8905,
                        0
                        -3.0395,
                        51.8605,
                        0
                        -2.7995,
                        51.8305,
                        0
                        -2.5495,
                        51.8005,
                        0
                        -2.2895,
                        51.7705,
                        0
                        -2.0395,
                        51.7405,
                        0
                        -1.7895,
                        51.7105,
                        0
                        -1.5395,
                        51.6805,
                        0
                        -1.2895,
                        51.6505,
                        0
                        -1.0395,
                        51.6205,
                        0
                        -0.7895,
                        51.5905,
                        0
                        -0.5395,
                        51.5605,
                        0
                        -0.2895,
                        51.5305,
                        0
                        -0.0395,
                        51.4905,
                        0
                        0.2105,
                        51.4605,
                        0
                        0.4605,
                        51.4305,
                        0
                        0.7105,
                        51.3905,
                        0
                        0.9505,
                        51.3605,
                        0
                        1.2005,
                        51.3205,
                        0
                        1.4505,
                        51.2805,
                        0
                        1.6905,
                        51.2405,
                        0
                        1.9405,
                        51.2005,
                        0
                        2.1805,
                        51.1605,
                        0
                        2.4305,
                        51.1205,
                        0
                        2.6705,
                        51.0805,
                        0
                        2.9105,
                        51.0405,
                        0
                        3.1405,
                        51.0005,
                        0
                        3.3805,
                        50.9605,
                        0
                        3.6105,
                        50.9205,
                        0
                        3.8505,
                        50.8805,
                        0
                        4.0805,
                        50.8405,
                        0
                        4.3205,
                        50.7905,
                        0
                        4.5505,
                        50.7505,
                        0
                        4.7805,
                        50.7105,
                        0
                        5.0005,
                        50.6605,
                        0
                        5.2305,
                        50.6205,
                        0
                        5.4505,
                        50.5805,
                        0
                        5.6705,
                        50.5305,
                        0
                        5.9005,
                        50.4905,
                        0
                        6.1205,
                        50.4405,
                        0
                        6.3405,
                        50.4005,
                        0
                        6.5505,
                        50.3605,
                        0
                        6.7505,
                        50.3205,
                        0
                        6.9405,
                        50.2805,
                        0
                        7.1205,
                        50.2505,
                        0
                        7.3005,
                        50.2105,
                        0
                        7.4705,
                        50.1805,
                        0
                        7.6405,
                        50.1405,
                        0
                        7.8105,
                        50.1105,
                        0
                        7.9705,
                        50.0805,
                        0
                        8.1405,
                        50.0405,
                        0
            "properties": {
                "description": "\n \n <table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n </table>\n <b>Beam Information:</b>\n <table>\n <tr><td><i>Beam ID:</i></td><td>71</td></tr>\n <tr><td><i>Beam Name:</i></td><td>W2A</td></tr>\n </table>\n <p><i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i></p>\n <p><a href=\"http://flightfeed.panasonic.aero/All/HistoryFlight.php?FlightID=1051876\">more...</a></p>\n <p><a href=\"https://swa-wiki.mascorp.com/bin/view/SWA/FFPPT\">FlightFeed Wiki</a></p>\n \n ",
                "stroke-width": 2
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -78.95,
                    43.7,
                    0
            "properties": {
                "name": "D-ABVY - Login",
                "styleUrl": "#LOGIN",
                "styleHash": "69949246",
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>23:20:00 - Aug 26 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>G17</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>4.580dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-2.345dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-6.40dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>63</td></tr>\n <tr><td><i>Latency:</i></td><td>547.541s</td></tr>\n <tr><td><i>Jitter:</i></td><td>412.906</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -65.73,
                    48.04,
                    0
            "properties": {
                "name": "D-ABVY - Logoff",
                "styleUrl": "#LOGOFF",
                "styleHash": "-12805470",
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>00:29:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>G17</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.070dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-3.623dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-6.40dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>63</td></tr>\n <tr><td><i>Latency:</i></td><td>706.904s</td></tr>\n <tr><td><i>Jitter:</i></td><td>5.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -65.12,
                    48.27,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>00:32:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.260dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>5.321dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-5.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>748.566s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.000</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -65.12,
                        48.27,
                        0
                        -65.73,
                        48.04,
                        0
            "properties": {
                "name": "D-ABVY - Beam Switch",
                "styleUrl": "#BeamSwitchSegment_Good_HISTORY",
                "styleHash": "-3c25d859",
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Beam Switch:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>00:29:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>00:32:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Switch Duration:</i></td><td>00:03:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>G17</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.070dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-3.623dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-6.40dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>63</td></tr>\n <tr><td><i>Latency:</i></td><td>706.904s</td></tr>\n <tr><td><i>Jitter:</i></td><td>5.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.260dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>5.321dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-5.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>748.566s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.000</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -59.66,
                    49.79,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>00:59:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.450dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.339dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>718.181s</td></tr>\n <tr><td><i>Jitter:</i></td><td>44.185</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -59.13,
                    49.92,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:01:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.470dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.411dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1293.310s</td></tr>\n <tr><td><i>Jitter:</i></td><td>131.770</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -59.13,
                        49.92,
                        0
                        -59.66,
                        49.79,
                        0
            "properties": {
                "name": "D-ABVY - Offline",
                "styleUrl": "#OfflineSegment_HISTORY",
                "styleHash": "-3d628f72",
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>00:59:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>01:01:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.450dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.339dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>718.181s</td></tr>\n <tr><td><i>Jitter:</i></td><td>44.185</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.470dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.411dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1293.310s</td></tr>\n <tr><td><i>Jitter:</i></td><td>131.770</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -58.2,
                    50.17,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:06:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.110dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.502dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>762.673s</td></tr>\n <tr><td><i>Jitter:</i></td><td>13.778</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -57.79,
                    50.28,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:08:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.100dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.461dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>1108.870s</td></tr>\n <tr><td><i>Jitter:</i></td><td>128.106</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -57.79,
                        50.28,
                        0
                        -58.2,
                        50.17,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>01:06:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>01:08:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.110dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.502dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>762.673s</td></tr>\n <tr><td><i>Jitter:</i></td><td>13.778</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.100dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.461dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>1108.870s</td></tr>\n <tr><td><i>Jitter:</i></td><td>128.106</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -57.58,
                    50.34,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:09:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.180dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.613dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>734.237s</td></tr>\n <tr><td><i>Jitter:</i></td><td>6.476</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -57.06,
                    50.47,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:11:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.210dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.168dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>967.119s</td></tr>\n <tr><td><i>Jitter:</i></td><td>89.633</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -57.06,
                        50.47,
                        0
                        -57.58,
                        50.34,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>01:09:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>01:11:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.180dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.613dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>734.237s</td></tr>\n <tr><td><i>Jitter:</i></td><td>6.476</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.210dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.168dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>967.119s</td></tr>\n <tr><td><i>Jitter:</i></td><td>89.633</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -54.89,
                    51.01,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:22:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.180dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.890dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>991.158s</td></tr>\n <tr><td><i>Jitter:</i></td><td>56.127</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -54.48,
                    51.1,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:24:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.280dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.930dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>759.740s</td></tr>\n <tr><td><i>Jitter:</i></td><td>67.174</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -54.48,
                        51.1,
                        0
                        -54.89,
                        51.01,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>01:22:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>01:24:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.180dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.890dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>991.158s</td></tr>\n <tr><td><i>Jitter:</i></td><td>56.127</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.280dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.930dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>759.740s</td></tr>\n <tr><td><i>Jitter:</i></td><td>67.174</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -49.84,
                    52.02,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:46:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.440dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.785dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-13.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>771.971s</td></tr>\n <tr><td><i>Jitter:</i></td><td>55.778</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -49.19,
                    52.11,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>01:49:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.460dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.401dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-13.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>776.034s</td></tr>\n <tr><td><i>Jitter:</i></td><td>14.958</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -49.19,
                        52.11,
                        0
                        -49.84,
                        52.02,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>01:46:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>01:49:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:03:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.440dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.785dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-13.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>771.971s</td></tr>\n <tr><td><i>Jitter:</i></td><td>55.778</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.460dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.401dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-13.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>776.034s</td></tr>\n <tr><td><i>Jitter:</i></td><td>14.958</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -40.77,
                    52.95,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:26:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.320dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.748dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>749.353s</td></tr>\n <tr><td><i>Jitter:</i></td><td>39.840</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -40.42,
                    52.97,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:28:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.330dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.629dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1020.200s</td></tr>\n <tr><td><i>Jitter:</i></td><td>51.725</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -40.42,
                        52.97,
                        0
                        -40.77,
                        52.95,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>02:26:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>02:28:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.320dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.748dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>749.353s</td></tr>\n <tr><td><i>Jitter:</i></td><td>39.840</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.330dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.629dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1020.200s</td></tr>\n <tr><td><i>Jitter:</i></td><td>51.725</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -38.76,
                    53.04,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:35:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.540dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.894dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>773.313s</td></tr>\n <tr><td><i>Jitter:</i></td><td>77.969</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -38.16,
                    53.06,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:37:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.390dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.756dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1615.320s</td></tr>\n <tr><td><i>Jitter:</i></td><td>217.760</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -38.16,
                        53.06,
                        0
                        -38.76,
                        53.04,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>02:35:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>02:37:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.540dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.894dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>773.313s</td></tr>\n <tr><td><i>Jitter:</i></td><td>77.969</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.390dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.756dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>1615.320s</td></tr>\n <tr><td><i>Jitter:</i></td><td>217.760</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -35.71,
                    53.11,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:48:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.580dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.937dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>732.987s</td></tr>\n <tr><td><i>Jitter:</i></td><td>25.327</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -35.24,
                    53.11,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>02:50:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.510dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.875dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>731.101s</td></tr>\n <tr><td><i>Jitter:</i></td><td>2.118</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -35.24,
                        53.11,
                        0
                        -35.71,
                        53.11,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>02:48:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>02:50:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.580dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.937dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>732.987s</td></tr>\n <tr><td><i>Jitter:</i></td><td>25.327</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.510dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.875dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>731.101s</td></tr>\n <tr><td><i>Jitter:</i></td><td>2.118</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -31.6,
                    53.06,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:05:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.370dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.661dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>814.955s</td></tr>\n <tr><td><i>Jitter:</i></td><td>80.249</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -31.25,
                    53.05,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:07:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.340dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.632dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>717.666s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.835</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -31.25,
                        53.05,
                        0
                        -31.6,
                        53.06,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>03:05:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>03:07:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.370dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.661dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>814.955s</td></tr>\n <tr><td><i>Jitter:</i></td><td>80.249</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.340dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.632dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>717.666s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.835</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -27.08,
                    53.38,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:25:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.630dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.627dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>787.435s</td></tr>\n <tr><td><i>Jitter:</i></td><td>12.694</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -26.5,
                    53.44,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:27:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.640dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.599dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>726.006s</td></tr>\n <tr><td><i>Jitter:</i></td><td>4.344</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -26.5,
                        53.44,
                        0
                        -27.08,
                        53.38,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>03:25:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>03:27:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.630dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.627dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>787.435s</td></tr>\n <tr><td><i>Jitter:</i></td><td>12.694</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.640dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.599dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-14.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>511</td></tr>\n <tr><td><i>Latency:</i></td><td>726.006s</td></tr>\n <tr><td><i>Jitter:</i></td><td>4.344</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -21.9,
                    53.87,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:47:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.980dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.020dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>991.490s</td></tr>\n <tr><td><i>Jitter:</i></td><td>25.526</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -21.3,
                    53.91,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>03:49:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.080dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.352dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>785.945s</td></tr>\n <tr><td><i>Jitter:</i></td><td>163.038</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -21.3,
                        53.91,
                        0
                        -21.9,
                        53.87,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>03:47:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>03:49:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.980dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.020dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>991.490s</td></tr>\n <tr><td><i>Jitter:</i></td><td>25.526</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.080dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.352dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>785.945s</td></tr>\n <tr><td><i>Jitter:</i></td><td>163.038</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -17.08,
                    54.03,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:07:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.090dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.738dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>717.625s</td></tr>\n <tr><td><i>Jitter:</i></td><td>71.814</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -16.6,
                    54.03,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:09:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.990dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.733dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>673.368s</td></tr>\n <tr><td><i>Jitter:</i></td><td>63.087</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -16.6,
                        54.03,
                        0
                        -17.08,
                        54.03,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:07:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:09:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.090dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.738dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>717.625s</td></tr>\n <tr><td><i>Jitter:</i></td><td>71.814</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.990dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.733dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>673.368s</td></tr>\n <tr><td><i>Jitter:</i></td><td>63.087</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -11.54,
                    53.43,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:30:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.250dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.004dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>693.917s</td></tr>\n <tr><td><i>Jitter:</i></td><td>1.637</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -11.19,
                    53.36,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:32:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.170dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.777dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>688.877s</td></tr>\n <tr><td><i>Jitter:</i></td><td>48.963</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -11.19,
                        53.36,
                        0
                        -11.54,
                        53.43,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:30:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:32:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.250dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.004dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>693.917s</td></tr>\n <tr><td><i>Jitter:</i></td><td>1.637</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>6.170dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.777dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>688.877s</td></tr>\n <tr><td><i>Jitter:</i></td><td>48.963</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -9.12,
                    52.95,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:41:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.865dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>690.627s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.103</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -8.66,
                    52.85,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:43:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.017dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>676.346s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -8.66,
                        52.85,
                        0
                        -9.12,
                        52.95,
                        0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Not connected:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:41:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:43:00 - Aug 27 GMT</td></tr>\n</table>\n<table>\n <tr><td><i>Offline Duration:</i></td><td>00:02:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.865dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>690.627s</td></tr>\n <tr><td><i>Jitter:</i></td><td>0.103</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.017dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>676.346s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -8.66,
                    52.85,
                    0
            "properties": {
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    -6.86,
                    52.44,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>04:51:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>W2A</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>3.150dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.656dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-5.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>15</td></tr>\n <tr><td><i>Latency:</i></td><td>717.565s</td></tr>\n <tr><td><i>Jitter:</i></td><td>230.597</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "LineString",
                "coordinates": [
                        -6.86,
                        52.44,
                        0
                        -8.66,
                        52.85,
                        0
            "properties": {
                "styleUrl": "#BeamSwitchSegment_Bad_HISTORY",
                "styleHash": "-4e7a7bdb",
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Beam Switch:</b>\n<table>\n <tr><td><i>Logoff Time:</i></td><td>04:43:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Login Time:</i></td><td>04:51:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Switch Duration:</i></td><td>00:08:00</td></tr>\n</table>\n<b>Logoff Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>T14R</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>5.940dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-1.017dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-15.00dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>255</td></tr>\n <tr><td><i>Latency:</i></td><td>676.346s</td></tr>\n <tr><td><i>Jitter:</i></td><td>3.762</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>33.330%</td></tr>\n</table>\n<b>Login Beam:</b>\n<table>\n <tr><td><i>Name:</i></td><td>W2A</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>3.150dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.656dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-5.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>15</td></tr>\n <tr><td><i>Latency:</i></td><td>717.565s</td></tr>\n <tr><td><i>Jitter:</i></td><td>230.597</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "type": "Point",
                "coordinates": [
                    8.14,
                    50.04,
                    0
            "properties": {
                "description": "<table>\n <tr><td><i>Flight ID:</i></td><td>1051876</td></tr>\n <tr><td><i>Antenna:</i></td><td>Melco</td></tr>\n</table>\n<b>Modem Login Event:</b>\n<table>\n <tr><td><i>Login Time:</i></td><td>05:56:00 - Aug 27 GMT</td></tr>\n <tr><td><i>Beam Name:</i></td><td>W2A</td></tr>\n <tr><td><i>Signal to Noise Downlink:</i></td><td>1.120dB</td></tr>\n <tr><td><i>Signal to Noise Uplink:</i></td><td>-0.155dB</td></tr>\n <tr><td><i>Transmit Power:</i></td><td>-6.50dB</td></tr>\n <tr><td><i>MODCOD:</i></td><td>7</td></tr>\n <tr><td><i>Latency:</i></td><td>695.622s</td></tr>\n <tr><td><i>Jitter:</i></td><td>9.407</td></tr>\n <tr><td><i>Packet Loss:</i></td><td>0.000%</td></tr>\n</table>\n<i>Snapshot Time: - 2015-08-27 12:59:07 GMT</i>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        -79.6308,
                        43.678,
                        0
                        -78.9495,
                        43.7005,
                        0
            "properties": {
                "name": "D-ABVY (departure)",
                "styleUrl": "#LEADERTRAILER",
                "styleHash": "53ee4950",
                "description": "\n<p><b>Departure Airport:</b>\n<table>\n\t<tr><td><i>IATA:</i></td><td>YYZ</td></tr>\n\t<tr><td><i>ICAO:</i></td><td>CYYZ</td></tr>\n\t<tr><td><i>Name:</i></td><td>Toronto Pearson International Airport</td></tr>\n\t<tr><td><i>Country:</i></td><td>Canada</td></tr>\n</table>\n\n"
            "type": "Feature",
            "geometry": {
                "coordinates": [
                        8.1405,
                        50.0405,
                        0
                        8.5707,
                        50.0484,
                        0
            "properties": {
                "name": "D-ABVY (destination)",
                "description": "\n<p><b>Destination Airport:</b>\n<table>\n\t<tr><td><i>IATA:</i></td><td>FRA</td></tr>\n\t<tr><td><i>ICAO:</i></td><td>EDDF</td></tr>\n\t<tr><td><i>Name:</i></td><td>Frankfurt International Airport</td></tr>\n\t<tr><td><i>Country:</i></td><td>Germany</td></tr>\n</table>\n\n"
You should be able to get the positions with entity.polyline.positions.
You can add pins using GeoJSON like this:
  "type": "Feature",
  "geometry": {
    "type": "Point",
    "coordinates": [
      0.0,
      0.0
  "properties": {
    "title": "Unnamed",
    "marker-color": "#B9EB14"
Take a look at this example to see all of the pin options: http://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=GeoJSON%20simplestyle.html&label=DataSources
Hannah
Dear Hannah,
thank you so much for replying. I am getting closer to resolve this issue.
Using entity.polyline.positions i can get coordinates but they are completely different then what i have in geojson data file.
For example i have
  "coordinates": [
                        -78.9495,
                        43.7005,
                        0
                        -78.8095,
                        43.7505,
                        0
Using entity.polyline.positions i am getting
x: 2211849.053838839
y: -3413704.679021972
z: 4896264.598621493
__proto__: o
1: o
x: 2216400.0262421216
y: -3407680.918278572
z: 4898387.940045211
Am i making any mistake ?
Thanks again you are the best.
The positions have been converted from Cartographic longitude/latitude positions to Cartesian3 positions. You can get an array of all positions converted to Cartographic coordinates like this:
var cartesianPositions = entity.polyline.positions;
var cartographicPositions = viewer.scene.globe.ellipsoid.cartesianArrayToCartographicArray(cartesianPositions);
var longitude = cartographicPositions[0].longitude;
var latitude = cartographicPositions[0].latitude;
var height = cartographicPositions[0].height;
Hope this helps!
-Hannah
Hi Hannah,
Thanks for replying.
However i am getting
0: o
height:9.313225746154785
latitude: 0.7627176097677816
longitude: -1.3779287178032633
instead of this -
-78.9495,
43.7005,
0
Here is the code --
                console.log("entities_positions");
                for (var i = 0; i < entities.length; i++) {
                    entity = entities[i];
                      var cartographicPositions = viewer.scene.globe.ellipsoid.cartesianArrayToCartographicArray(cartesianPositions._value);
                      console.log(longitude);
                      console.log(latitude);
Is there no simple way to access.
This part (coordinates) from my file above.
"type": "Feature",
            "geometry": {
                "coordinates": [
                        -58.1995,
                        50.1705,
                        0
If this did not work i can use javascript/jquery to get coordinates values. But i thought this is not correct way!
Thanks
Those coordinates are given in radians. You can convert them back to degrees with Cesium.Math.toDegrees(radianValue).
-Hannah
Thank you so much Hannah.
It works.............
I am building a application and i will show you when it is done.
Thanks again you are really very helpful.
Great! Can’t wait to see it finished!
Glad I could help =)
-Hannah
Hi Hannah,
I have one quick question.
Do i need to use any other external file in order to use KmlDataSource.load();
i am using <script type="text/javascript" src="Cesium-1.13/Build/Cesium/Cesium.js"></script>
Thanks
See the KmlDataSource reference documentation: http://cesiumjs.org/Cesium/Build/Documentation/KmlDataSource.html#load
It looks like load will accept a url, parsed KML document, or Blob containing binary KMZ data or a parsed KML document.
-Hannah
Hi Hanna,
Great Forum!
You advised using "entity.polyline.positions" which is great for polylines; but how can this work for Polygons?
I tried: entity.polygon.PolygonHierarchy.positions
Suggestions?
Thanks!
Javascript is case sensitive. Using entity.polygon.polygonHierarchy.positions instead should work.
Hannah
Thanks for the help.
Just thought I would share that it seems to be just "entity.polygon.hierarchy" if there are no holes... this code below was added to Sandcastle/Polygon for the redPolygon.
Cheers, David
// Original Points for redPolygon, first point shown only...
console.log("Original : Lon: -115.0, Lat: 37.0");
// Get polygon positions
var pos = redPolygon.polygon.hierarchy;
console.log("Cartesian: "+pos.getValue(viewer.clock.currentTime)[0].toString());
// Convert to cartographic radians
var carto = viewer.scene.globe.ellipsoid.cartesianArrayToCartographicArray(pos._value);
var lon = carto[0].longitude;
var lat = carto[0].latitude;
var hgt = carto[0].height;
console.log("Radians : Lon: "+lon.toString()+" Lat: "+lat.toString()+" Height: "+hgt.toString());
// Convert to degrees
var LON = Cesium.Math.toDegrees(lon);
var LAT = Cesium.Math.toDegrees(lat);
var HGT = Cesium.Math.toDegrees(hgt);
console.log("Degrees : Lon: "+LON.toString()+" Lat: "+LAT.toString()+" Height: "+HGT.toString());
