Hi!
I'm trying to show pictures coming from CZML file into the InfoBox Widget, but the image is not coming.
I Attached the screenshot and the CZML file.
I'm adding a link to the picture in the DESCRIPTION field of the czml as an html <img> tag. This is the entire CZML (if you drag and drop this to the Cesium Viewer you can see it)
“id”:“document”, “version”:“1.0”,
“clock”:{
“interval”:“2014-01-01T12:00:00Z/2014-09-15T12:00:00Z”,
“currentTime”:“2014-09-15T12:00:00Z”,
“range”:“LOOP_STOP”,
“step”:“SYSTEM_CLOCK_MULTIPLIER”
“id”:“1”,
“availability”: “2014-04-24T18:04:22Z/2014-09-15T12:00:00Z”,
“position”:{
“cartographicDegrees”: [-0.976240521700356, 51.4609894403789, 0]
“point”:{
“color”:{
“rgba”:[0,0,255,95]},
“pixelSize”:40,“show”:true
“description”:“PICTURE: <br> <br><div> <img src=‘http://demo.coffeyidevuk.com/Demos/CosmosGISWebApi/pictures/1_MINI.jpeg’ height=‘300’ width=‘300’> </img> <br> <br>Device: 1<br>Wave: 1<br>Time Stamp: 24/04/2014 18:04:22<br>Latitude: 51.4609894403789<br>Longitude: -0.976240521700356<br>Altitude: 0<br>Speed: 0<br>GPS Horizontal accuracy: 59<br>GPS vertical accuracy: 0<br>”
The other elements of the html works fine, but not the <img> tab. I'm doing something wrong?
Thanks in advance!
