Basically i have a model aircraft and setting the position and heading, pitch, roll. My question is regarding the heading. Everything is working perfectly except that when heading is reaching to a borderline for instance 359 degrees (heading values in degrees ranging from 0 - 359.9999) and the next item/record the heading value is 2.0 degrees, the model just turns/rotates a complete ~360 degrees turn. I believe my code here does not account for this particular scenario where the heading value in in the borderline (358 degrees to 2 degrees).
Here's a sample of my code:
function positionModel() {
var point = new Cesium.Cartographic(currentFlightData.longitude, currentFlightData.latitude, currentFlightData.altitude);
var epoint = cesiumViewer.scene.globe.ellipsoid.cartographicToCartesian(point);
var heading = currentFlightData.heading;
var pitch = currentFlightData.pitch;
var roll = currentFlightData.roll;
var currentTranslation = new Cesium.Cartesian3();
var currentRotation = new Cesium.Matrix3();
var eastNorthUp = Cesium.Transforms.eastNorthUpToFixedFrame(epoint);
Cesium.Matrix4.getRotation(eastNorthUp, currentRotation);
Cesium.Matrix4.getTranslation(eastNorthUp, currentTranslation);
var headingQuaternion = Cesium.Quaternion.fromAxisAngle(Cesium.Cartesian3.UNIT_Z, -heading );
var pitchQuaternion = Cesium.Quaternion.fromAxisAngle(Cesium.Cartesian3.UNIT_Y, -pitch);
var rollQuaternion = Cesium.Quaternion.fromAxisAngle(Cesium.Cartesian3.UNIT_X, -roll);
var headingPitchQuaternion = Cesium.Quaternion.multiply(headingQuaternion, pitchQuaternion, new Cesium.Quaternion());
var finalQuaternion = new Cesium.Quaternion();
Cesium.Quaternion.multiply(headingPitchQuaternion, rollQuaternion, finalQuaternion);
var rM = new Cesium.Matrix3();
Cesium.Matrix3.fromQuaternion(finalQuaternion, rM);
Cesium.Matrix3.multiply(currentRotation, rM, currentRotation);
var modelMatrix = new Cesium.Matrix4();
Cesium.Matrix4.fromRotationTranslation(
currentRotation,
currentTranslation,
modelMatrix
aircraftModel.modelMatrix = modelMatrix;
