Hi.
I have a code written in cesium 1.9 and i want it to work in cesium 1.46.
What changes in code syntax I have to made.
When I am using cesium.js 1.9 with below code its working fine.
But with cesium.js 1.46 is show error…
Uncaught SyntaxError: Invalid regular expression: /[×-ת؀-Û¿Ý-ݿࢠ-ࣿ]/: Range out of order in character class
at new RegExp ()
at Cesium.js:489
at c (Cesium.js:451)
at a (Cesium.js:451)
Code… in cesium 1.9
var gibs = gibs || {};
gibs.Viewer = function(config) {
// Earliest date of Corrected Reflectance in archive: May 8, 2012
var startTime = Cesium.JulianDate.fromDate(
new Date(Date.UTC(2018, 4, 8)));
var endTime = Cesium.JulianDate.now();
// If slightly after midnight, show the previous day’s data while
// the near-real time imagery is processing.
var show = new Date();
if ( show.getUTCHours() < 12 ) {
show.setUTCDate(show.getUTCDate() - 1);
var initialTime = Cesium.JulianDate.fromDate(show);
// Keep track of the previous day. Only update the layer on a tick if the
// day has actually changed.
var previousTime = null;
var selectedSet = null;
var clock = new Cesium.Clock({
currentTime: initialTime,
multiplier: 0, // Don’t start animation by default
startTime: startTime,
endTime: endTime,
clockRange: Cesium.ClockRange.CLAMPED
// GIBS needs the day as a string parameter in the form of YYYY-MM-DD.
// Date.toISOString returns YYYY-MM-DDTHH:MM:SSZ. Split at the “T” and
// take the date which is the first part.
var isoDate = function(isoDateTime) {
return isoDateTime.split(“T”)[0];
// Create the layer for the current day
var createProvider = function(layer_id) {
var layer = config.layers[layer_id];
var time = “”;
if ( layer.startDate ) {
var isoDateTime = clock.currentTime.toString();
time = “?TIME=” + isoDate(isoDateTime);
var provider;
if ( !layer.wms ) {
var resolution = config.resolutions[layer.resolution];
var options = {
url: “//map1.vis.earthdata.nasa.gov/wmts-geo/wmts.cgi” + time,
layer: layer.id,
style: “”,
format: layer.format,
tileMatrixSetID: resolution.tileMatrixSetID,
minimumLevel: 0,
maximumLevel: resolution.maximumLevel,
tileWidth: 512,
tileHeight: 512,
tilingScheme: gibs.GeographicTilingScheme()
if ( layer.credit ) {
options.credit = layer.credit;
provider = new Cesium.WebMapTileServiceImageryProvider(options);
} else {
var options = {
url: “//map2.vis.earthdata.nasa.gov/wms/wms.php” + time,
layers: layer.id,
parameters: {
transparent: true,
format: “image/png”
provider = new Cesium.WebMapServiceImageryProvider(options);
return provider;
// Invoked when the current day changes, but do not call this too often
// if the user is sweeping through days.
var updateLayers = _.throttle(function() {
var time = isoDate(isoDateTime);
var layers = viewer.scene.imageryLayers;
layers.removeAll();
_.each(selectedSet.layers, function(layer_id) {
layers.addImageryProvider(createProvider(layer_id));
var legend = selectedSet.legend;
if ( !legend ) {
$("#legend").hide();
} else if ( legend.type === “scale” ) {
$(".legend-title").html(legend.title);
$(".legend-colorbar").attr(“src”, legend.colorbar);
$(".legend-max").html(legend.max);
$(".legend-min").html(legend.min);
$("#legend .single").hide();
$("#legend .scale").show();
$("#legend").show();
} else {
$(".legend-color").css(“background-color”, legend.color);
$("#legend .scale").hide();
$("#legend .single").show();
}, 250, {leading: true, trailing: true});;
// When the clock changes, check to see if the day has changed and
// replace the current layers/
var onClockUpdate = function() {
if ( time !== previousTime ) {
previousTime = time;
updateLayers();
var models = ;
_.each(config.sets, function(set) {
var model = new Cesium.ProviderViewModel({
tooltip: “Hello”,
iconUrl: set.icon,
creationFunction: function() {
// Return an empty set and update the layers in the same
// way done when the clock changes.
selectedSet = set;
_.defer(updateLayers);
return ;
models.push(model);
var viewer = new Cesium.Viewer(“map”, {
clock: clock,
imageryProviderViewModels: models,
terrainProviderViewModels:
viewer.timeline.zoomTo(startTime, endTime);
viewer.clock.onTick.addEventListener(onClockUpdate);
onClockUpdate();
viewer.scene.globe.baseColor = Cesium.Color.BLACK;
var getLeadingPoint = function() {
// Set default extent according to time of day:
// at 00:00 UTC, start at far eastern edge of map: “20.6015625,-46.546875,179.9296875,53.015625”
// at 23:00 UTC, start at far western edge of map: “-179.9296875,-46.546875,-20.6015625,53.015625”
var curHour = new Date().getUTCHours();
// For earlier hours when data is still being filled in, force a far eastern perspective
if (curHour < 3) {
curHour = 23;
// Adjust for globe view
curHour -= 5;
// Compute east/west bounds
var minLon = 20.6015625 + curHour * (-200.53125/23.0);
var maxLon = minLon + 159.328125;
var minLat = -46.546875;
var maxLat = 53.015625;
return new Cesium.Rectangle(
Cesium.Math.toRadians(minLon),
Cesium.Math.toRadians(minLat),
Cesium.Math.toRadians(maxLon),
Cesium.Math.toRadians(maxLat)
viewer.camera.viewRectangle(getLeadingPoint());
return viewer;
Source of Code: view-source:http://nasa-gibs.github.io/gibs-web-examples/examples/cesium/gibs-layers/
at new RegExp ()
at Cesium.js:489
