I created a simple outline of a house:
As seen in the image, its not really the result one would want to show the walls of a house.
I created it with the following code, looping over a geosjon polygon outer ring.
for (let j = 0; j < coordinates.length-1; j++) {
let flatten1 = .concat.apply(, [coordinates[j], coordinates[j+1]]);
var material = new Cesium.ImageMaterialProperty({
image: ‘/src/demos/hus/content/B543_mork_885x885-300x300.png’,
repeat: new Cesium.Cartesian2(5.0, 5.0)
var wall_1 = this._dataSource.entities.add({
wall: {
positions: Cesium.Cartesian3.fromDegreesArrayHeights(flatten1),
material: material
I want to create a 3d visualization of a house.
Latest from npm and chrome.
Anyone have any input on better ways to use a image patch as the texture for the wall. The current implementation above also would need one to calcualte the repease property to get nice results. Is there not a better way?
