How to use hardware antialias?
I am setting context option “antialias: true”, but it does not have any effect. Is there any way to use Cesium JS without offscreen rendering and having the hardware antialias enabled?
We would need best possible line-quality. The postprocess FXAA does not cut it…
Newest version.
I’ve recently run into this as well, and I documented it here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8228
As far as I can tell, fixing this would require adding some MSAA pass, which seems to be why the model looks better in ThreeJS, but I haven’t had a chance to confirm/toggle that in ThreeJS.
