I could show NY 3d tiles but I couldn't show own Japanese 3d tiles 'PLATEAU'
I could show NY 3d tiles by Cesium for Unreal.
I referred to this quickstart Cesium for Unreal Quickstart | cesium.com
but I couldn’t show own Japanese 3d tiles
I downloaded them from https://www.geospatial.jp/ckan/dataset/plateau-tokyo23ku-3dtiles-2020 and upload to Cesium Ion.
anything wrong ?
Output logs.
LogCesium: Error: [2021-04-02 11:09:51.232] [error] [Tileset.cpp:697] Tileset did not contain a geometricError
LogCesium: Display: 13122_katsushika-ku_notexture: 90 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 1, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 228 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 245 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 99, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 252 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 79, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 280 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 78, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 288 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 65, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 335 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 59, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 349 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 58, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 358 ms, Visited 100, Culled Visited 0, Rendered 1, Culled 571, Max Depth Visited: 7, Loading-Low 571, Loading-Medium 54, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58467 ms, Visited 133, Culled Visited 0, Rendered 81, Culled 74, Max Depth Visited: 15, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 58466 ms, Visited 88, Culled Visited 0, Rendered 88, Culled 473, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 58491 ms, Visited 89, Culled Visited 0, Rendered 89, Culled 472, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58501 ms, Visited 134, Culled Visited 0, Rendered 81, Culled 77, Max Depth Visited: 15, Loading-Low 4, Loading-Medium 0, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 58500 ms, Visited 88, Culled Visited 0, Rendered 88, Culled 463, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58509 ms, Visited 133, Culled Visited 0, Rendered 80, Culled 78, Max Depth Visited: 15, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58517 ms, Visited 134, Culled Visited 0, Rendered 81, Culled 77, Max Depth Visited: 15, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58534 ms, Visited 133, Culled Visited 0, Rendered 80, Culled 78, Max Depth Visited: 15, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: 13122_katsushika-ku_notexture: 58533 ms, Visited 89, Culled Visited 0, Rendered 89, Culled 462, Max Depth Visited: 7, Loading-Low 0, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58543 ms, Visited 133, Culled Visited 0, Rendered 79, Culled 82, Max Depth Visited: 15, Loading-Low 4, Loading-Medium 0, Loading-High 0
LogCesium: Display: CesiumWorldTerrain: 58551 ms, Visited 133, Culled Visited 0, Rendered 79, Culled 82, Max Depth Visited: 15, Loading-Low 0, Loading-Medium 0, Loading-High 0
The Japanese 3d tiles were shown in Cesium ion web site.
regards.
I think it’s the rotation question,I have the same question
Thanks. I’ll see and follow your question.
@ranxie
I think it’s a different from your case.
There is no ''gltfUpAxis" in my tileset.json.
Hi @hisayan,
We’re investigating this one. It may just be that we don’t (yet) support the CESIUM_RTC extension. See Support CESIUM_RTC glTF extension and use it for RTC_CENTER b3dm property · Issue #195 · CesiumGS/cesium-native · GitHub.
Kevin
Thanks. @Kevin_Ring
I’ll try to convert from RTC_CENTER.
I set some parameters on ‘transform’ in each contents of the tileset.json. (affine transformation)
I resolved it. thanks.
this is my prototype.
I made a conversion tool. And I made it open source.
