Can you interpret these results as to why IE is not able to run Cesium?
Our clients won't be able to turn off IE Software rendering and their graphics cards are going to be worse than mine, so I need to be able to get it running smoothly locally before having any hope that the map will be usable by clients.
Ah, okay. I don’t think there’s anything we can do if IE is blocking hardware accelerated graphics for those machines, sorry. As Matt said in that other forum post, you could try updating IE and your graphics card drivers if those aren’t up to date.
You could consider using TerriaJS, which has a fallback to 2D (Leaflet) for systems that can’t run Cesium well for whatever reason. https://github.com/TerriaJS/terriajs
