I’m looking to bring in this data at 30 sec intervals https://public-api.adsbexchange.com/VirtualRadar/AircraftList.json
https://cesiumjs.org/Cesium/Apps/Sandcastle/?src=Hello%20World.html&label=Showcases&gist=018b15051aee315bbc74f3e87fb5b336 produces no errors
This code doesn’t appear to work: var viewer = new Cesium.Viewer(‘cesiumContainer’);
viewer.dataSources.add(Cesium.GeoJsonDataSource.load(‘https://public-api.adsbexchange.com/VirtualRadar/AircraftList.json’, {
stroke: Cesium.Color.ROYALBLUE,
fill: Cesium.Color.YELLOW,
strokeWidth: 3,
markerSymbol: ‘airport-15.svg’
Demo purposes
Cesium 1.36
Windows 10
Google Chrome
Thank you,
Darryl
Hi Darryl,
Take a look at our Cesium Workshop Tutorial, particularly the section on Loading and Styling Entities. It includes loading in data sources and then applying styles.
If we break your provided code into something a little simpler we can see what’s going wrong.
Cesium.GeoJsonDataSource.load(‘https://public-api.adsbexchange.com/VirtualRadar/AircraftList.json’)
.then(function (dataSource) {
console.log('Successfully loaded!');
Plug it into Sandcastle and look at the console, it looks like the “Successfully loaded!” line never gets called, and instead we get a message Request has failed.
Taking a look at the contents of your provided JSON file, that doesn’t look like GeoJson format, which would be why the request is failing. Can you determine what forma the data is?
Gabby
Hi Gabby , thank you.
I switched functions as per the documentation GeoJsonDataSource doesn’t load from urls while loadJson does, however plugging that into Sandcastle doesn’t appear to do anything
Cesium.loadJson(‘https://public-api.adsbexchange.com/VirtualRadar/AircraftList.json’)
console.log(‘Successfully loaded!’);
No error, but no success either.
As for format, it’s a JSON format from commercial aircraft transmitters
Thanks again!
Darryl
Hi Darryl,
If I run your example, I get “Request has failed” again, and if I open developer tools (ctrl+shift+i in chrome), I see
XMLHttpRequest cannot load https://public-api.adsbexchange.com/VirtualRadar/AircraftList. No ‘Access-Control-Allow-Origin’ header is present on the requested resource. Origin ‘https://cesiumjs.org’ is therefore not allowed access. The response had HTTP status code 404.
This is an issue with CORS not being enabled on the server you are requesting from. See this thread for more information.
Gabby
Okay, I made the update to my code
var planes = Cesium.loadJson(‘https://public-api.adsbexchange.com/VirtualRadar/AircraftList.json’,{
proxy : new Cesium.DefaultProxy(’/proxy/’)
But now it’s giving me a a 403 error. I’d say it’s an origin issue but curl --insecure works flawlessly.
Thank you!
It looks like the server does not accept the ‘Access-Control-Allow-Origin’ header, which is necessary to request via JavaScript for security reasons.
Can you contact the owner of the server and ask them to allow the ‘Access-Control-Allow-Origin’ header?
Gabby
