Importing GeoJSON, DEM/DTM Data to Unreal Engine through Cesium ion
Hi, nice to meet you all, I hope somebody can help me with this.
I need some help with different data and Cesium in Unreal Engine 5. I want to simulate my city but i want to do it with my own data. I’m using GeoTIFF aerial images, DEM/DTM(as GeoTIFF), Shapefiles (as JSON files), but I’m having some issues:
      - I upload JSON to Cesium ion and it works perfect (I can visualize it in the viewport of ion). The problem comes when I try to import it in Unreal Engine 5 if I import it as 3D Tiles nothing happens and if I import it as GeoJSON i cannot import it to unreal because a message appears saying "This type of asset is not currently supported". How can I fix this and import my buildings? I missed something? Here i give you some info which is in my JSON files:
"type": "FeatureCollection",
"name": "Buildings_BIG",
"crs": { "type": "name", "properties": { "name": "urn:ogc:def:crs:OGC:1.3:CRS84" } },
"features": [
{ "type": "Feature", "properties": { "ID": 207442151.0, "ESTAD_0507": "01", "ETIQUETA": null, "F_ALTA": "2021/05/29", "ID_BIC": null, "ID_BICCA": null, "ID_NG": null, "NOMBRE": null, "PRIORIDAD": null, "TIPO_0507": "01" }, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ -3.961940694689462, 42.784782280493005, 754.7 ], [ -3.961959806428111, 42.784832189575909, 754.2 ], [ -3.961961587552271, 42.784836677278015, 754.1 ], [ -3.961888564698292, 42.784858183069922, 754.2 ], [ -3.961904056135062, 42.784879575676804, 753.8 ], [ -3.961878435540822, 42.784890957503407, 754.0 ], [ -3.961814438165822, 42.784918961323704, 753.9 ], [ -3.961788943964611, 42.784930612228514, 754.1 ], [ -3.961761503370571, 42.784887612620608, 755.2 ], [ -3.961785506036161, 42.784882282483302, 755.0 ], [ -3.961766064833532, 42.784826878384813, 755.3 ], [ -3.961842963681921, 42.784810923418213, 755.2 ], [ -3.961940694689462, 42.784782280493005, 754.7 ] ] ] ] } },
{ "type": "Feature", "properties": { "ID": 207397064.0, "ESTAD_0507": "01", "ETIQUETA": null, "F_ALTA": "2021/05/29", "ID_BIC": null, "ID_BICCA": null, "ID_NG": null, "NOMBRE": null, "PRIORIDAD": null, "TIPO_0507": "01" }, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ -3.961926455120172, 42.78604271842692, 755.7 ], [ -3.961852819447642, 42.785961564098123, 754.9 ], [ -3.961939453394522, 42.785918871522313, 754.7 ], [ -3.962007838122712, 42.786000430123423, 755.1 ], [ -3.962012569924151, 42.786005973673809, 755.1 ], [ -3.961983181568173, 42.786018828028716, 755.3 ], [ -3.962000844484192, 42.786038311256306, 755.4 ], [ -3.961981620635342, 42.78607593492201, 755.9 ], [ -3.961962526968011, 42.786082489109113, 756.0 ], [ -3.961926455120172, 42.78604271842692, 755.7 ] ] ] ] } },
{ "type": "Feature", "properties": { "ID": 207526221.0, "ESTAD_0507": "01", "ETIQUETA": null, "F_ALTA": "2021/05/29", "ID_BIC": null, "ID_BICCA": null, "ID_NG": null, "NOMBRE": null, "PRIORIDAD": null, "TIPO_0507": "01" }, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ -3.961905833880081, 42.785231673633312, 751.5 ], [ -3.961887004030621, 42.785231561648501, 751.6 ], [ -3.961835650149261, 42.785231272590813, 751.8 ], [ -3.961834489473821, 42.785243169374915, 751.8 ], [ -3.961825365736901, 42.785246127716512, 751.8 ], [ -3.961798587622052, 42.785253827062427, 751.9 ], [ -3.961793596501812, 42.78525521978402, 751.9 ], [ -3.961744621005741, 42.785258512840407, 752.1 ], [ -3.961722785773532, 42.785166931923811, 753.4 ], [ -3.961731210884641, 42.785166230790303, 753.2 ], [ -3.961812533693951, 42.785159604231104, 752.2 ], [ -3.961870337195901, 42.785157948003416, 751.6 ], [ -3.961898445053712, 42.785157171574127, 751.4 ], [ -3.961901880813641, 42.785189561898818, 751.4 ], [ -3.961959176378291, 42.785186288933708, 750.9 ], [ -3.961959205657172, 42.785188179806909, 751.0 ], [ -3.961953275934662, 42.785231995521698, 751.2 ], [ -3.961905833880081, 42.785231673633312, 751.5 ] ] ] ] } },
{ "type": "Feature", "properties": { "ID": 207349829.0, "ESTAD_0507": "01", "ETIQUETA": null, "F_ALTA": "2021/05/29", "ID_BIC": null, "ID_BICCA": null, "ID_NG": null, "NOMBRE": null, "PRIORIDAD": null, "TIPO_0507": "01" }, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ -3.961878435540822, 42.784890957503407, 754.0 ], [ -3.961917512144282, 42.784919536359411, 752.8 ], [ -3.961853269309801, 42.784955376900207, 752.7 ], [ -3.961814438165822, 42.784918961323704, 753.9 ], [ -3.961878435540822, 42.784890957503407, 754.0 ] ] ] ] } },
{ "type": "Feature", "properties": { "ID": 207392720.0, "ESTAD_0507": "01", "ETIQUETA": null, "F_ALTA": "2021/05/29", "ID_BIC": null, "ID_BICCA": null, "ID_NG": null, "NOMBRE": null, "PRIORIDAD": null, "TIPO_0507": "01" }, "geometry": { "type": "MultiPolygon", "coordinates": [ [ [ [ -3.961888418281921, 42.786223864934705, 756.1 ], [ -3.961958355428322, 42.786239851734422, 756.5 ], [ -3.961965594467662, 42.786241501932722, 756.5 ], [ -3.961908811733261, 42.786380210722108, 756.2 ], [ -3.961841343146532, 42.78636573856582, 756.0 ], [ -3.961832378699261, 42.786363202319812, 755.9 ], [ -3.961888418281921, 42.786223864934705, 756.1 ] ] ] ] } },
    - I tried to import DEM/DTM with an aerial image as a GeoTIFF but nothing happened, only DEM world terrain appeared. Any trick here? as I explained I must use my own data.
   - I tried to import LiDAR files and I can put them into the game engine properly but I cannot visualize them in the viewport.
Hi @GuillermoPerz,
Sorry to hear you’re having trouble! You should definitely be able to import your won GeoTIFF elevation data and imagery. However, not all the data types you are using are currently supported in Cesium for Unreal.
Shapefiles are not currently supported in Cesium for Unreal, so you won’t be able to import them using the plugin. You may be able to import them using some other tool.
LiDAR point clouds are also not yet supported in Cesium for Unreal. Some work has been done experimentally to support point clouds, but it’s not a part of the main plugin and may not be compatible with your data. If you want to take a look, you can find more information here - Add point cloud rendering (support glTF POINTS geometry) by nithinp7 · Pull Request #627 · CesiumGS/cesium-unreal · GitHub
As for your elevation data, you mentioned you can only see DEM world terrain. Is this in Cesium ion, or Cesium for Unreal? Can you share any screenshots?
-Alex
Hi @agallegos didn’t noticed you answered me!
First of all, thanks for help about shapefiles and LiDAR.
Right now I’m quite stucked trying to push the data to Unreal Engine and testing in asset-server. I send you a screenshot of the cmd, -d where I have the files and the .terraindb and the web browser. In the web browser I tried different things to try the visualization of the .terraindb always starting with http://localhost:8002/ . I tried:
  • With all the directory: /10062022/dem/Data
  • Only with the beginning, the middle or the end of the directory: /10062022 ; /dem ; /Data
  • Only with the name of the .terraindb: /Name
I don’t know If I’m missing something important because I cannot vizualize it in the browser ot in Unreal Engine (in Unreal I use the same URL but in the end I add /layer.json).
I hope you can give me here a hand.
Thanks!
Hi @GuillermoPerz,
You should be able to access the tileset at http://localhost:8002/DB/layer.json, both in your web browser and your Unreal project.
Let me know if that works for you!
-Alex
Morning!
Yes, I solved it doing exactly that. I understood layer.json is in the terraindb not outside as another file! thanks!
