I am attempting to install CesiumJS on a Centos 8 host using NGINX as the web server.
I need help with configuring NGINX to point to CesiumJS location. Here is a snippet of nginx.conf that is pointing to Cesium …
server {
listen 8085 default_server;
listen [::]:80 default_server;
server_name geoweb01;
root /www/cesium;
# Load configuration files for the default server block.
include /etc/nginx/default.d/*.conf;
location / {
location /Apps/ {
In the web browser I’m using … http://geoweb01:8085/Apps/HelloWorld.html … the result is and NGINX error message … “404 … not found”
How do I set the path correctly so that NGINX can server CesiumJS?
