I'm getting and instanceIndex error when removing polylines. This cause seems to be from this issue https://github.com/AnalyticalGraphicsInc/cesium/issues/4983, but I'm not quite sure if it is something that can happen due to misuse of the framework's code. I don't see anywhere in our code where we directly call PolylineCollection.update() btw.
Create and remove polylines without error
1.49.0
