iOS Build Error (Blend2D missing)
When exporting my Unity project to Xcode and building for iOS, I encounter linker errors related to undefined Blend2D symbols such as:
_blContextBegin
_blContextDestroy
_blContextEnd
_blContextInit
_blImageCreateFromData
_blImageDestroy
_blImageInit
I checked my Assets/Plugins/iOS and the exported Xcode project, but I do not see any libblend2d.a or Blend2D framework included. Because of this, the iOS build fails.
Could you clarify:
Should libblend2d.a be bundled with Cesium for Unity? If not, what is the correct way to include Blend2D for iOS builds?
Do I need to manually build Cesium Native / Blend2D from source and add it to Unity? (Current Cesium for Unity version : 1.17.0 )
Hi @akashc,
Thank you for this report. This is a known issue that has been recorded on Github here:
We recognize this is breaking behavior, and I apologize on the behalf of the team for the inconvenience. We are investigating and determining a fix so we can get this into the next release.
Hi @akashc,
I’ve just opened a pull request with a fix for this:
So it should be fixed in our next release. In the meantime, you can try out a pre-release build from this branch:
You can easily install it by going here and downloading the “Combined Package” artifact:
Then extract the .tar.gz file found inside it, and add it to your project using the Unity package manager.
Let me know if that solves the problem for you!
Yes I tried downloading the .tgz file from git, it installed successfully and i was able to build for iOS without any trouble.
Thanks for the update.
@Kevin_Ring , I’m also facing same issue when building iOS build from unreal engine
Hi @Kevin_Ring , Any update on the following issue for unreal engine?
Happy to hear it is solvable. Waiting for the update.
@Mayank_i are you still experiencing this problem in Cesium for Unreal v2.20.0, which was released at the beginning of October?
Thanks @Kevin_Ring , for the update. Latest update of the plugin surely removed these errors while building for iOS through unreal engine.
