Is distanceDisplayCondition is working with czml??
distanceDisplayCondition is not working czml
Here is sample url sandcastle.
czml for model not support many option like billboard & label.
eg. scaleByDistance / translucencyByDistance …
so i should onlyuse minimumPixelSize & maximumScale options.
But these options have limit.
So i wanna utilize with “distanceDisplayCondition” option.
but it look not working
1.63 . Chrome. WIn10 64bit
Thank you
A CZML is a JSON file. You can’t create an instance of a class and pass it in that way.
See the CZML guide for how to use distance display condition in CZML: https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/DistanceDisplayConditionValue
So it would just be an array with the two values.
Hi Omar.
code
“distanceDisplayCondition” : {
“distanceDisplayCondition” : [
50, 200
is working
Thank you
