I have a question Lennart:
I would ike to apply disableDethTestdistance und DistanceDisplayCondition together,
i.E.
between 0 and x : depthTest
between 0 and y: distanceTest
whereas x < y
→ this means between x and y no depthTest is applied
I tried this in the following sandcastle, but in hte case I set the distanceDisplayCondition the depthTest isn’t working ?
Comment out the distanceDisplayCondition and set the worldTerrain for tests !
I also though, that the value in the disableDepthTest works that the test is disabled at this value → bigger than x the depthTest is not applied.
Do you have any idea - help ?
