scaleByDistance at czml is not working ??
czml label and scaleByDistance option is not working.
Is it normal??
or is there any thing i miss ??
Thank you!
var czml = [{
“id” : “document”,
“name” : “Basic CZML billboard and label”,
“version” : “1.0”
“id” : “some-unique-id”,
“name” : “AGI”,
“description” : “
Analytical Graphics, Inc. (AGI) founded Cesium.
“billboard” : {
“image” : “data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACvSURBVDhPrZDRDcMgDAU9GqN0lIzijw6SUbJJygUeNQgSqepJTyHG91LVVpwDdfxM3T9TSl1EXZvDwii471fivK73cBFFQNTT/d2KoGpfGOpSIkhUpgUMxq9DFEsWv4IXhlyCnhBFnZcFEEuYqbiUlNwWgMTdrZ3JbQFoEVG53rd8ztG9aPJMnBUQf/VFraBJeWnLS0RfjbKyLJA8FkT5seDYS1Qwyv8t0B/5C2ZmH2/eTGNNBgMmAAAAAElFTkSuQmCC”,
“scale” : 1.5
“label” : {
“fillColor” : {
“rgba” : [255, 255, 255, 255]
“font” : “12pt Lucida Console”,
“horizontalOrigin” : “LEFT”,
“pixelOffset” : {
“cartesian2” : [8, 0]
“style” : “FILL”,
“text” : “Test_Text”,
“scaleByDistance” : new Cesium.NearFarScalar(1.5e5, 0.1, 1.5e7, 0.01),
“showBackground” : true,
“backgroundColor” : {
“rgba” : [112, 89, 57, 200]
“position” : {
“cartographicDegrees” : [126.69248300366301, 37.45092668898614, 0.0]
I wanna show many czml label through mariadb
so label shown small to user
label is about building/bus stop/metro station information
1.59
latest Chrome
Win10 64bit
https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/Label
At czml-guide github there are description about scaleByDistance label.
but not working
You can’t add a direct instance of a CesiumJS class to CZML (since that’s not something you can store in a JSON document without serializing). So you need to replace:
With:
“scaleByDistance” : {
“nearFarScalar”: [1.5e5, 0.1, 1.5e7, 0.01]
Since that’s how a nearFarScalar is written in CZML (from https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/NearFarScalar).
Here’s a full Sandcastle you can run. Let me know if this helps!
Thats work !!
It was poor question.
Thank you Omar
I tried running your sandcastle. I uncommented the last line for scaleByDistance. I’m not seeing what difference it is making. I’m new to this site and I may not be understanding how the sample code works.
I was just trying to figure out if this is the feature I’m looking for.
Here’s a simpler Sandcastle showing how scaleByDistance works. It just allows you to change the size of the icon based on the distance to the camera. Try zooming in and out here to see.
Ok, thanks. That’s not what I was looking for.
