Hi, I try to add label to lines but it look like bad, is there any method for add stroke to label ?
I can not find it in document.
here is the result:
Thank you for your community forum post! Can you please share some more information about your current implementation? It looks like the text is showing up underneath the polylines. I wonder if there is a way to offset the text.
-Sam
I think its not about offset, yes may be I can set offset but label does not have stroke so it look like sallow
but with stroke you can read more easy:
here is my code sample:
viewer.entities.add({
position: lastPoint,
label: {
scale: 0.5,
text: `line: ${index}`,
polyline: {
positions: [firstPoint, lastPoint],
material: color,
I’m assuming that you are seeing the same issue when experimenting with this code? I took some time to look through your code and did not see any major issues. I would definitely love to learn more about how you are updating firstPoint and lastPoint. I am also wondering what you mean by this:
Looking forward to learning more!
-Sam
Sorry for translate, I cant remember word I mean it look blurred, with stroke you can prevent this.
firstPointandlastPoint.
I found new points around center point with different radius and angle. you can think like circle object.
