When the outer DOM container has transform: scale(n) and n is not equal to 1, it causes interaction offsets — the actual trigger point ends up at the position computed after the transform, including mouse controls over the camera and other mouse events.
Attempt 1:
Approach: Pre-calculate the scaling situation and set the canvas size according to the scaled values.
Result: Camera controls and interaction events match correctly, but it causes other elements in the scene to be synchronously scaled up/down.
Attempt 2:
Approach: Directly modify the source code in ScreenSpaceEventHandler.js, adding scale calculation to the getPosition method:
Hey @xinyi, thanks for the detailed write-up. Your analysis of ScreenSpaceEventHandler looks reasonable, but I’d like to see a minimal Sandcastle that reproduces the issue so we can confirm the behavior without any interference from other parts of your setup.
Could you put together a Sandcastle (using the HTML panel to wrap the cesiumContainer in a scaled parent div) that demonstrates the offset? That would make it much easier to validate your fix and would also serve as a solid reproduction case if you open a GitHub issue on the CesiumJS repo.
Sure, here’s the Sandcastle Demo. Clicking directly on the billboard does not trigger the interaction, but clicking at the inversely scaled position does.
If you’re interested, this would make a great PR contribution! The contributor’s guide is here: cesium/CONTRIBUTING.md at main · CesiumGS/cesium · GitHub
For future finds like this, feel free to open a GitHub issue directly too, it helps the team track and prioritize fixes.
