this is not a problem per se…I am just trying to see if the style of the points in a point cloud can be changed from the existing square looking point to a sphere or a circle?
I am looking at the sandcastle example at:
and
The points in the point cloud in both the sandcastle look square. Is there a way to render a point with my own point style (in this case as a sphere)?
Customer is requesting the points in the point cloud to be spherical instead of a square tile kind of point.
1.51
