omar
August 14, 2019, 2:44pm
2
Can you explain a bit more what you’re trying to do? You should be able to create an entity with a billboard and an image if that’s what you mean. See this Sandcastle example: https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Billboards.html
Perfect answer Omar, can I use as much unique images as I want or only one?
omar
August 14, 2019, 3:10pm
4
You can certainly use any arbitrary images, for example see the “Add multiple billboards” in the dropdown of that example on adding multiple different ones.
