Is there any Rotation event?
camera.changed.addEventListener does not working for rotation
Have you taken a look at the look functions in camera? These functions will rotate the camera around a certain vector (ex. up) by a specified or default amount.
I asked for an event and not a function so it will be triggered when the user rotate the camera.
My apologies for misreading the question. I am unable to reproduce the error. I made this Sandcastle that prints out to console each time the camera moves and it seems to be working for me on all camera changes.
Could you send a Sandcastle of the rotation not working?
Thank you for clarifying. What are you planning to achieve with the ctrl + rotate event?
There is no rotate event, but if you listen for the mouseDown event and set a mouseDown Boolean to true, you can then listen for mouseMove and do something if mouseDown is true on the mouseMove event. On mouseUp, set mouseDown to false. This will capture a drag/rotate event.
I build a compass so i want it to rotate when the user rotate the map.
My solution was to subscribe to camera moveStart - then I activate setInterval that sample the camera angle - then I clearInterval at camera moveEnd
I look for the same event - in case syncing 2D and 3D
also want to display a compass with north
