Hi
Im trying to load a KML (same issue with KMZ) file that I've generated in GE Pro.
Its basically full of Polygons, the problem i get is that it only displays the last polygon on the Cesium Page (I'm just using a very basic copy (edited version) of the Cesium KML example to load my own file.
Any ideas ?
Graham
Hi
Any ideas ?
can you share with us your KML file, so we can verify it ?
Regards
Roberto
BTW, how many elements it contains ? Do you have tested with less elements ?
Roberto
Hi Roberto,
Ive tried with various sized (elements) files, this one i must admit is more clomplex
Im trying to figure out how to add files to this .... will post then try and add
It looks like you have the same id for every placemark. I changed a couple and then those were displayed.
Scott
Ahh i see now
need to modify my matlab code
Thanks !!!! Duhhhh !!!
Yes, I tested with my new “Gaeta” QGIS plugin, and your file is published in Cesium, as you can see in this image:
https://drive.google.com/file/d/0By5p_WoL_LoFUTJrak5ZRXVBQnM/view?usp=sharing
So, it is not a problem of too many elements.
