I am trying to get this kmz file working in my version of Cesium (1.39) - "https://www.epa.gov/sites/production/files/2016-11/waters_data_1.8.kmz". It seems to load without error but does not function properly (i.e., like it does in Google Earth). When I zoom into a watershed boundary, it should update the map with the outlines of increasingly smaller subbasins. But it doesn't seem to refresh the views based on the network links for the data sources, and I can't figure it out based on my limited understanding of Cesium or find a CZML version.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, minimum-scale=1, user-scalable=no">
<meta name="description" content="A simple KML example.">
<meta name="cesium-sandcastle-labels" content="Showcases, DataSources">
<title>Cesium Demo</title>
<script type="text/javascript" src="../Sandcastle-header.js"></script>
<script type="text/javascript" src="../../../ThirdParty/requirejs-2.1.20/require.js"></script>
<script type="text/javascript">
require.config({
baseUrl : '../../../Source',
waitSeconds : 60
</script>
</head>
<body class="sandcastle-loading" data-sandcastle-bucket="bucket-requirejs.html">
<style>
@import url(../templates/bucket.css);
</style>
<div id="cesiumContainer" class="fullSize"></div>
<div id="loadingOverlay"><h1>Loading...</h1></div>
<div id="toolbar"></div>
<script id="cesium_sandcastle_script">
function startup(Cesium) {
'use strict';
//Sandcastle_Begin
var options = {
camera : viewer.scene.camera,
canvas: viewer.scene.canvas,
Sandcastle.addToolbarMenu([{
text: 'KMZ - watersheds',
onselect: function () {
viewer.camera.flyHome(0);
viewer.dataSources.add(Cesium.KmlDataSource.load('../../SampleData/waters_data_1.8.kmz', options));
}], 'toolbar');
Sandcastle.reset = function() {
viewer.dataSources.removeAll();
viewer.clock.clockRange = Cesium.ClockRange.UNBOUNDED;
viewer.clock.clockStep = Cesium.ClockStep.SYSTEM_CLOCK;
//Sandcastle_End
Sandcastle.finishedLoading();
if (typeof Cesium !== "undefined") {
startup(Cesium);
} else if (typeof require === "function") {
require(["Cesium"], startup);
</script>
</body>
</html>
Trying to build an interactive tool for modeling agricultural runoff.
Cesium 1.39, CefSharp with NodeJS .
