Does cesium for unity support linux release and operation?
We don’t current distribute binaries for Linux, but you can build them yourself by following the Developer Setup instructions:
Is there a development plan for supporting the Linux platform
It’s not currently a high priority, as we’ve generally found Linux users are willing and able to build it themselves.
Publishing platforms for Windows and Linux, hoping to release tutorials for the Linux platform
Hello! Can the execution program of the Linux version of cesium for unity compile successfully in the Windows environment? Compile in Linux environment?
It’s probably possible to cross-compile it for Linux on a Windows machine, but I haven’t tried it. Is that what you’re asking?
Can compile successfully in the window environment, but does not display maps on Linux
We do not ship binaries for Linux. If you need to run on Linux, you need to build the plugin yourself by following the Developer Setup instructions linked above. Have you done that?
HI,
I followed the Developer Setup instructions, but when I jump into build~ codes like Unity.cs and Packages.cs I found that there is code like if(OperatingSystem.IsMacOS()) and if(OperatingSystem.IsWindows()) but does not include Linux, so I guess I need to add some custom code for Linux, right?
Yes. The first step is to just get it working locally in the Editor, though, if you haven’t already. At that point you should even be able to package a game for Linux. The Build~ scripts are only needed when you want to package the Cesium for Unity plugin so that it can be used on systems without the full Cesium for Unity source code with Reinterop, a C++ compiler, etc.
