I load 60000 boxes to simulate the dynamic change of surface. When i add SampledProperty to box.dimension, then crash the browser. So how could add property to 60000 boxes?
In the mean I would recommend optimizing it by showing only what’s available in any given view, to visualize subsets of the data instead of all the data at once.
