how to load svg in cesium and change the shape of svg dynamically
You can add svg as an image texture for a billboard, something like:
viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883),
billboard :{
image : '../../../path/to/image/svg'
Then you can change the height or width or scale of the billboard: https://cesium.com/docs/cesiumjs-ref-doc/Billboard.html?classFilter=billboard
i need to change the path of svg such as from a line to a polyline rather than changing the scale like height or width.
Can you clarify what you mean by the path of svg? Are you referring to the image path (i.e. '../../../path/to/image/svg')?
For example,if the svg represent a straight line,It can be shown as straight or broken lines when it is shown in the cesium.
What is the case that the path would change? Time? You could set the image prop to be a CallbackProperty so that you could dynamically change it based on some condiiton
I don’t want to change the svg from a.svg to b.svg.I just want to use the a.avg all the time which i can modify shape.
