SVG as billboard's src doesn't work since Cesium 1.43
Until Cesium 1.43 I was able to set billboard's source to SVG.
Now I get an error:
Error loading image for billboard: [object Event]
I'm using latest Chrome v65.
var billboards = scene.primitives.add(new Cesium.BillboardCollection());
billboards.add({
    position : Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883, 150000),
    image : ‘https://raw.githubusercontent.com/google/material-design-icons/master/social/svg/production/ic_cake_48px.svg’
I need to draw display SVG for an entity.
Windows 7 & Windows 10, Cesium 1.43, Chrome 65
Look in the network tab, it seems like the response has some headers to prevent the image from being embedded like `
X-XSS-Protection:
1; mode=block`.
Can you download the image and serve it yourself?
Gabby
It is not about XSS.
I try to load SVG as data-uri (which means it's not hosted anywhere).
This is an example to code that doesn't work since version 1.43:
    viewer.entities.add({
        position : Cesium.Cartesian3.fromDegrees(-75.59777, 40.03883),
        billboard :{
            image: 'data:image/svg+xml;utf-8,<svg xmlns="http://www.w3.org/2000/svg" width="100" height="100"> <rect x="0" y="0" height="100" width="100" style="stroke:#ff0000; fill: #0000ff"/> </svg>'
Thank you!
