Loading Tiles Failing after a little while in Game
I have just launched the Cesium update for our game Glider Sim on Steam. Glider Sim - Earth Online Many users reporting tiles no longer load after a little while in game (after 3 or so minutes). Usually happens after switching scenes back to the main menu or entering back in to the game. Any idea what is going on? And why tiles fail to load?
I get these errors:
[2024-09-19 12:33:54.194] [error] [SqliteCache.cpp:441] database is locked
UnityEngine.Debug:Log (object)
Reinterop.ReinteropInitializer:UnityEngine_Debug_CallLog_FA05wu8x__otZNsgdHTnU9A (intptr) (at ./Library/PackageCache/com.cesium.unity@1.12.0/Runtime/generated/Reinterop.RoslynSourceGenerator/ReinteropInitializer.cs:61505)
[2024-09-19 22:21:56.927] [error] [TilesetContentManager.cpp:1049] An unexpected error occurs when loading tile: Request for https://assets.ion.cesium.com/us-east-1/asset_depot/1/CesiumWorldTerrain/v1.2/5/37/22.terrain?v=1.2.0&extensions=octvertexnormals-metadata failed: Unable to complete SSL connection
CesiumForUnity.Cesium3DTileset:Update () (at ./Library/PackageCache/com.cesium.unity@1.12.0/Runtime/generated/Reinterop.RoslynSourceGenerator/Cesium3DTileset-generated.cs:606)
Also. After I exit play mode after the errors occurred I get spammed this in the console window. Only way to fix it is to restart Unity.
"Exception: Request for https://api.cesium.com/v1/defaults failed: Cannot resolve destination host
UnityEngine.Debug:LogError (object)
Reinterop.ReinteropInitializer:UnityEngine_Debug_CallLogError_FA05wu8x__otZNsgdHTnU9A (intptr) (at ./Library/PackageCache/com.cesium.unity@1.12.0/Editor/generated/Reinterop.RoslynSourceGenerator/ReinteropInitializer.cs:6463)
CesiumForUnity.CesiumIonSession:Tick () (at ./Library/PackageCache/com.cesium.unity@1.12.0/Editor/generated/Reinterop.RoslynSourceGenerator/CesiumIonSession-generated.cs:582)
CesiumForUnity.CesiumEditorUtility:UpdateIonSession () (at ./Library/PackageCache/com.cesium.unity@1.12.0/Editor/CesiumEditorUtility.cs:26)
UnityEditor.EditorApplication:Internal_CallUpdateFunctions ()
I also notice the “Use Existing Token” breaks and drop down no longer works. No tokens are displayed. The only way to fix the issue is to restart Unity. Or restart the Game.
Hi @5DRealities,
That’s a frustrating issue. Unfortunately I’m not sure from a glance what could be wrong. Could you please share more information so we can diagnose this?
  • What versions of the Unity Editor + Cesium for Unity are you using?
  • How have you installed the plugin? Did you install it through the Package Manager? Or did you build it yourself from Github?
  • What datasets are you using? I see that you’re getting an error for Cesium World Terrain in your log, but the website you linked mentions Google Photorealistic 3D Tiles.
Can you also confirm whether you’ve upgraded your Cesium ion account from the Community level to a higher tier?
Hi, yes this a frustrating issue. I still am getting many messages from users saying the data drops out mid game session.
-I am using Unity Version 2022.3.46
-Yes, I installed through Package Manager. Latest version 1.12.0
-I am using Bing Maps for our coordinate selection screen and Google 3D Tiles for the in-game scenery.
-I have upgraded to the Commercial Tier a couple months ago.
The data will fail to load usually after a scene change when going back to the Bing Map selection screen. Or sometimes when entering back into the game with the Google Photorealistic tiles. It usually always occurs with in 3 to 4 scene switches.
Also another thing I noticed in the latest version. Clicking “Google Photorealstic 3D Tiles”
Does nothing. And then clicking “Cesium World Terrain + Bing Maps Aerial” then adds “Google Photorealstic 3D Tiles” to the scene.
Perhaps an array reference is off by 1?
Are you all using OpenXR by any chance? Apparently there is (was?) some drama with OpenXR inexplicably disabling Unity’s internet access:
I’m kind of grasping at straws here. It’s a very strange (and frustrating!) problem.
This is unfortunately a known problem on high-DPI displays. Unity’s ScrollView control, which we are using on that panel, apparently doesn’t account for DPI correctly when determining where the user clicked. It’s usually possible to click the right thing with a little bit of patience and resizing of the window. It’s really annoying, but I don’t know of any way to fix it short of rewriting the panel to avoid using that control.
I have seen the OpenXR issue when working with the Meta Quest, but that is only for Android. We are running on Steam / Windows builds. And OpenXR is not running when starting the game in standard flatscreen mode. Plus I get a solid connection for the first couple minutes, then later the connection to the Cesium server eventually drops out.
I don’t think DPI is the issue here, as I can hover over the buttons with my mouse and they show the correct tool tip. But then I click the appropriate “+” button and they do the action as mentioned above.
I think it could be worth disabling OpenXR completely just out of an abundance of caution, but I agree it’s not too likely that is the problem.
Which leaves me with not a lot of ideas. Anything that you (or anyone here) can do to help me reproduce the problem myself so that I can investigate would be a huge help!
Yep, understood, and I see the same thing. However, when I change my monitor’s scaling factor to 100% (from its usual 150%) the problem goes away. I can’t swear DPI is the issue, nor can I explain why the hover indicator works fine while clicking does not, but that is currently my best understanding as to the source of the problem (specifically: a bug in Unity related to DPI or perhaps scaling).
My best guess to reproduce the issue is to set up a project with at least two scenes with Google Photorealistic Tiles. Then fly around the terrain for a couple min, then load the other scene, fly around the scene some, then do it again. Load back to the other scene and fly around again. Eventually the terrain data from the cesium servers is going to fail. That is what we are seeing in our project.
If you can create such a project, and if it does in fact fail after a little while for you, we will be happy to take a look at it.
Hi ! I have a similar problem. After some time, the connection to Cesium is lost. In addition, other UnityWebRequests stop working. Only restarting the Editor or Build helps. Has the problem been resolved ? I noticed that this has a direct connection with Unity and Cesium, because if I am not moving around the map, I can use other UnityWebRequests, but Cesium requests crashes everything after some time… Unity 2021.3.43f1 URP / Cesium 1.13.0
It seems to be mainly caused by a Unity bug found here: Unity Issue Tracker - "TlsException: Handshake failed - error code: UNITYTLS_INTERNAL_ERROR" error when a lot of web requests are sent within a few minutes
Be sure to upvote the issue. Looks like it’s resolved for unity v6 but not yet for unity 2022 and 2021. Hopefully the next Unity update will solve it as it has been driving me crazy. Fingers crossed.
I spent the whole day transferring the project to Unity 6000.0.24f1 LTS. Same problem…
It is crucial for my project that the connection is continuous… Everyone has this problem??
According to the bug report on Unity it should be fixed in 6000.0.25f1. Unity Issue Tracker - "TlsException: Handshake failed - error code: UNITYTLS_INTERNAL_ERROR" error when a lot of web requests are sent within a few minutes
I am still waiting for 2022.3.52f1 to be available for download. God pray it’s really fixed…
