In the following DrawCommand code, a red triangle is properly rendered at the right position, Washinton, DC.
But when changing the view from 3D to 2D or Columbus, the red triangle is rendered at wrong position, mid of Atlantic Ocean, and the triangle shape is distorted.
View in 3D
View in 2D
View in Columbus
I guess the reason is the transformation matrix used in the vertex shader(GLSL), czm_modelViewProjection.
It should be changed to something else for 2D/Columbus view, but I have no idea.
I have looked for a sample code using DrawCommand and work well both in 3D and 2D, but as far now, I can’t find anything.
Your kind advice would be highly appreciated.
var scene = viewer.scene;
const basePosition = [ -77., 39.]; // Washington, DC
let sizing = 10.
let position0 = Cesium.Cartesian3.fromDegrees(basePosition[0]-sizing, basePosition[1]-(sizing/2.), 0);
let position1 = Cesium.Cartesian3.fromDegrees(basePosition[0] , basePosition[1]+(sizing/2.), 0);
let position2 = Cesium.Cartesian3.fromDegrees(basePosition[0]+sizing, basePosition[1]-(sizing/2.), 0);
let positions = [
position0.x,position0.y,position0.z,
position1.x,position1.y,position1.z,
position2.x,position2.y,position2.z];
scene.primitives.add(new MyPrimitive());
function MyPrimitive() {
this.drawCommand = undefined;
MyPrimitive.prototype.update = function(frameState) {
if (Cesium.defined(this.drawCommand)) {
frameState.commandList.push(this.drawCommand);
var context = frameState.context;
var vertexBuffer = Cesium.Buffer.createVertexBuffer({
context: context,
typedArray: new Float32Array(positions),
usage: Cesium.BufferUsage.STATIC_DRAW
var indexBuffer = Cesium.Buffer.createIndexBuffer({
context: context,
typedArray: new Uint16Array([0,1,1,2,2,0]),
usage: Cesium.BufferUsage.STATIC_DRAW,
indexDatatype: Cesium.IndexDatatype.UNSIGNED_SHORT
var attributes = [{
index: 0,
enabled: true,
vertexBuffer: vertexBuffer,
componentsPerAttribute: 3,
componentDatatype : Cesium.ComponentDatatype.FLOAT,
normalize: false,
offsetInBytes: 0,
strideInBytes: 0
var vs =
"attribute vec3 position; \n" +
"void main() { \n" +
" gl_Position = czm_modelViewProjection * vec4(position, 1.0); \n" +
"} \n";
var fs =
" gl_FragColor = vec4(1.0, 0.0, 0.0, 1.0); \n" +
"} \n";
var shaderProgram = Cesium.ShaderProgram.fromCache({
context: context,
vertexShaderSource: vs,
fragmentShaderSource: fs
var vertexArray = new Cesium.VertexArray({
context : context,
attributes : attributes,
indexBuffer : indexBuffer
var renderState = Cesium.RenderState.fromCache({
cull: {
enabled: true,
face: Cesium.CullFace.FRONT
depthTest: {
// enabled: true
enabled: false
depthMask: true,
blending: undefined
var drawCommand = new Cesium.DrawCommand({
//owner: this,
vertexArray : vertexArray,
shaderProgram : shaderProgram,
modelMatrix : Cesium.Matrix4.IDENTITY,
renderState : renderState,
cull : false,
primitiveType : Cesium.PrimitiveType.LINES,
pass : Cesium.Pass.OPAQUE,
this.drawCommand = drawCommand;
