Adding entities (or any kind of Cesium object with a definitionChanged object) to an Entity as a non-standard key causes a listener to be added to it, and not removed.
Sandcastle example:
We are trying to dynamically add and remove objects from an Entity, or assign things such as SampledPositionProperties, however the process of doing this causes listeners to build up.
1.36, OSX 10.12. Chrome 60
