Model shifts during change from 3d to 2d view
I am a beginner with Cesium and hit a weird issue. Placed a 3d model in glb format on the map in 3d view and aligned it to the coordinates. In 3d view, the model lines up with the roads and the green select box is right at the center of the model. In 2d and 2.5d mode the model goes to the left a bit and when I try to select it the green select box is outside it.
exports.createModel = function createModel(viewer, longitude, latitude, heading, name, description, url) {
    var position = Cesium.Cartesian3.fromDegrees(longitude, latitude, 0.0);
    var heading = heading;
    var pitch = 0;
    var roll = 0;
    var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
    var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
        position: position,
        orientation: orientation,
        description: description,
        model: {
            uri: url,
            scale: 1,
This is what I use to add the entity.
I just need a way to place an entity on the map and for it to stay there in all three view modes.
Cesium 1.39, Ubuntu 17.10, Mozilla Quantum, Chrome (Version 62.0.3202.89 (Official Build) (64-bit))
I can supply screenshots if needed
Hi Andrei,
Sorry for the delay, but can you please provide screenshots? I’m not sure what you mean by the “green select box”. Can you provide a sandcastle example?
Gabby
Models are still not perfect in 2D mode - more discussion here: https://github.com/AnalyticalGraphicsInc/cesium/issues/5112
Sorry for the late response, its indeed the same issue as the one presented on github ( https://github.com/AnalyticalGraphicsInc/cesium/issues/5112 ).
Fortunately the requirements allowed me to use 3d view and building were where they should be.
Thanks for all the help
