I wanted to move the model dynamically using keyboard shortcuts. I could not find relevant article on that.
So for now, I’m trying to move the model on click. When click on the model. The model has to move in one direction (increment the value 1 on tick). Find below the sandcastle code for that.
var selectedMesh; var i=0;
infoBox: false,
selectionIndicator: false
var handle = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
function createModel(url, height) {
viewer.entities.removeAll();
var position = Cesium.Cartesian3.fromDegrees(-123.0744619, 44.0503706, height);
var heading = Cesium.Math.toRadians(135);
var pitch = 0;
var roll = 0;
var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, heading, pitch, roll);
position: position,
orientation: orientation,
model: {
uri: url,
minimumPixelSize: 128
viewer.clock.onTick.addEventListener(function () {
if (selectedMesh) {
console.log("Before 0 : " + selectedMesh.primitive.modelMatrix[12]);
selectedMesh.primitive.modelMatrix[12] = selectedMesh.primitive.modelMatrix[12] + 1;
console.log("After 0 : " + selectedMesh.primitive.modelMatrix[12]);
handle.setInputAction(function (movement) {
console.log("LEFT CLICK");
var pick = viewer.scene.pick(movement.position);
if (Cesium.defined(pick) && Cesium.defined(pick.node) && Cesium.defined(pick.mesh)) {
if (!selectedMesh) {
selectedMesh = pick;
var options = [{
text: 'Aircraft',
onselect: function () {
createModel('../../SampleData/models/CesiumAir/Cesium_Air.bgltf', 5000.0);
text: 'Ground vehicle',
createModel('../../SampleData/models/CesiumGround/Cesium_Ground.bgltf', 0);
text: 'Milk truck',
createModel('../../SampleData/models/CesiumMilkTruck/CesiumMilkTruck.bgltf', 0);
text: 'Skinned character',
createModel('../../SampleData/models/CesiumMan/Cesium_Man.bgltf', 0);
Sandcastle.addToolbarMenu(options);
When I click, the model is moving for the first time. After that, It stays on the same place. I’ve printed the value in the console. It seems the value is not changing. I’m not sure about the problem here. or I’m implementing the transformation wrongly.
Any kind of help is appreciated. Thanks in advance.
