Multiple synced 3D views
I understand that cesium is supporting multiple synced views(3D and 2D) as in below sandcastle example.
However, Is there a way to have multiple 3D synced views. It is possible to sync the position and zoom, but I don’t know how to sync the 3D rotation. Please help me with this?
Thank you,
Arith.
I assume you got the 3D sync views to work, but the rotation is not syncing. Is this a correct assumption?
I made a Sandcastle with the 3D views side by side, where the rotation does sync.
What I did here was I replaced the 2D view parameters (starting from line 10) with the exact same parameters as the 3D view from the original Sandcastle you posted above.
Hello dzung,
Thank you for the help and prompt reply. I got that working earlier. What I meant by rotation is Ctrl + left/Right click rotation. That is what I am struggling to sync. Is there any solution for that.
Thank you,
Arith.
