My first Cesium app gives me just a white blank page.
I copied the codes of the first app which is at the link below but it gives me a blank white page; nothing in it. I have run it on multiple computers and with multiple browsers but the results are the same. My access token is already there in the template, so I have nothing to do but just copying and pasting it to glitch. But it won't let me get it.
<!DOCTYPE html>
<html lang="en">
<head>
  <script src="https://cesiumjs.org/releases//Build/Cesium/Cesium.js"></script>
  <link href="https://cesiumjs.org/releases//Build/Cesium/Widgets/widgets.css" rel="stylesheet">
</head>
<body>
  <div id="cesiumContainer" style="width: 700px; height:400px"></div>
  <script>
    Cesium.Ion.defaultAccessToken = 'MY ACCESS TOKEN';
  </script>
</body>
</html>
Just want to build my first app by following the tutorial.
I didn't think I need to install Cesium because the codes above do not refer to my own Cesium.
It looks like those links are missing a version number! If you replace:
With
https://cesiumjs.org/releases/1.51/Build/Cesium/Cesium.js
It should work. The tutorial is supposed to auto-generate the new version number and put it there with each release, so this must have recently broken. Thanks for reporting this, I’ll see if I can get it fixed right away.
Let me know if you run into any other issues, and welcome to Cesium!
This should be fixed now!
Yay! Now it's working! Thank you very much Omar!
