Can you show an image of the issue? My best guess is that it could be that the tiles don’t cover the entire globe to Cesium is attempting to use it to fill the entire space, as described here:
Hi Oumar, I have produced different tests and the rendering still is the same.
I’ve generated tile set with gdal or geographic imager, i’m on a epsg:4326 projection and the result is the same as the photo I’ve sent.
I was just going to suggest that, by default, Cesium will reproject the imagery which will cause that stretching, but it’s strange that this is still happening even after supplying imagery in epsg:4326.
Did you make sure to set the target SRS as well as the source SRS?
I think this stretching is expected of anything using the Web Mercator tiling scheme, which goes to infinity at the poles. So you can see this happens even with the default Cesium ion imagery.
However, the Natural Earth imagery that ships with Cesium is in Geographic, so the poles look normal, which you can see in this example:
You could also try explicitly setting the tiling scheme to GeographicTilingScheme when creating your imagery provider in Cesium, see:
I and thanks for our answer, yes I thing webmercator projector cause this issue.
Have you got any simple exemple in order to achieve a GeographicTilingScheme. I’ve already try before without success cause I don’t understand the way to achieve this.
I think the issue might be that your TIF file doesn’t cover the poles. Notice that the maxx and maxy in your XML output are 179.9 and 88 as opposed to 180 and 90. Can you try running gdalinfo (https://www.gdal.org/gdalinfo.html) ? It should output the corner coordinates, which should verify whether or not your source imagery covers the poles.
If you know what your imagery’s limits are, you can define a cartographicLimit rectangle to prevent it from trying to stretch it over the whole globe:
