A need a more accurate ellipse in regard to it's edge points. Needs to be smoother.
Currently ellipses are made with very few points, creating jagged sharp edges, I need it to be made with 1000 so that it's more accurate.
I haven't found a way to do this. My only other option is to make a polyline that is made to look like an ellipse, it'll take a lot more work though.
Thanks for all the help you can give.
1.48
