Object Camera focus
I am uploading a czml file that includes 2 satellites i am trying to zoom to the satellites in orbit when the file is uploaded.
I have attached my czml file and my HTML file.
i tried using :
viewer.zoomTo(dataSource.entities.getById('SAT1'));
but i see no change also i used this function that i found in examples:
dataSourcePromise.then(function(dataSource){
        viewer.trackedEntity = dataSource.entities.getById('SAT1');
    }).otherwise(function(error){
        window.alert(error);
as of right now im just trying to zoom to 1 satellite but i would like to be able to view both satellites together and how they move around each other in one view.
I am using the most current version of cesium and google chrome is my browser
Feb26-Test.czml (142 KB)
index3.html (2.77 KB)
I can’t run your example because it seems to be missing a satellite gltf model. Are you able to recreate this in Sandcastle (or a Glitch app (https://glitch.com/edit/#!/cesium-template)?) this would make it easier for me to run.
Currently, the camera can only track/zoom to one entity at a time. To do this you could get the position of both satellites, compute some average position and have the camera zoom/fly to that to make sure they’ve both in view. There’s a couple of camera examples on Sandcastle, here’s one that might be helpful:
I currently don’t have a model for the satellite when I run it I have some text that says SAT1 and SAT2 that serve as the current model.
