I have an old czml file from the demos prior to the 1.0 release. When I try to load it, I don’y get any errors but no contents from the file load(or are visible). Is there a way to edit/convert the file so that it will load correctly?
Scott
Scott
There’s no automated converter. The exact changes depends on the type of data being loaded. For example, if you have polygons/polylines, they now have a positions property on themselves rather than a vertexPositions property at the packet level.
