I would like to only display the 3d model, without displaying the globe, sun, and all other elements that come with the globe.
How does one remove all those elements from the cesium display?
I’ve looked through all the sandcastle examples, but found nothing of help.
To turn off globe rendering, you can use this code snippet.
globe: false
or
viewer.scene.globe.show = false;
To turn off sky and atmosphere rendering
viewer.scene.skyAtmosphere.show = false;
viewer.scene.skyBox.show = false;
To hide timeline widget
const viewer = new Cesium.Viewer(“cesiumContainer”, {
timeline : false
To hide clock
animation : false,
To hide all toolbar button
baseLayerPicker : false,
homeButton : false,
sceneModePicker : false,
navigationHelpButton : false,
geocoder : false
To hide the ion credit display widget
viewer.bottomContainer.style.display = “none”;
To hide the the fullcreen button
viewer.fullscreenButton.container.style.display = “none”;
For further detail please read below link
https://cesium.com/docs/cesiumjs-ref-doc/Viewer.html#.ConstructorOptions
Hope this help you!
Here are the things that ZehfengJin & Scott stated with direct settings (not through viewer parameter object attributes.)
var viewer = new Cesium.Viewer("cesiumContainer");
viewer.scene.sun.show=false;
viewer.scene.moon.show=false;
viewer.bottomContainer.style.display = "NONE"; //capitalized
viewer.fullscreenButton.container.style.display = "none"; //not capitalized
viewer.homeButton.container.style.display="none";
viewer.navigationHelpButton.container.style.display="none";
viewer.timeline.container.style.display="none";
Without the sun and moon and showing a model. Double-click the model to be able to rotate around it.
// https://community.cesium.com/t/only-display-3d-model-without-globe/10545
globe: false,
timeline : false,
animation : false,
homeButton : false,
geocoder : false
var scene = viewer.scene;
scene.sun = new Cesium.Sun();
scene.sun.show = false;
scene.moon = new Cesium.Moon({
show: false});
// To turn off sky and atmosphere rendering
// To hide the ion credit display widget
viewer.bottomContainer.style.display = 'none';
// To hide the the fullcreen button
viewer.fullscreenButton.container.style.display = 'none';
// Create an entity
var cesiumAir = viewer.entities.add({
position: new Cesium.Cartesian3.fromRadians(-1.31968, 0.698874, 74.14210186070714),
model: {
uri: "../../SampleData/models/CesiumAir/Cesium_Air.glb",
viewer.zoomTo(cesiumAir);
<\code><\pre>
Hi @ZhefengJin
any clue about a way to switch the globe on and off programmatically? Say I have a checkbox input true/false
viewer.scene.globe.show = inputVariable;
Cesium Sandcastle example
The above does not have any effects when the inputVariable changes from true to false and viceversa. Any suggestion?
thank you in advance
fm
In your flip function, you switch just the value of the variable bool, not viewer.scene.globe.show.
Change your filp function as follows.
function flip(){
viewer.scene.globe.show = !viewer.scene.globe.show;
