I’m using cesium for google earth map but i want to remove cesium animator
Is it possible to remove this div
Thanks
Thanks
Welcome to the community!
As we see in the Viewer documentation, we can set both animation and timeline to false.
https://cesium.com/learn/cesiumjs/ref-doc/Viewer.html
Here is a sandcastle demo that showcases how this can be done.
Let me know if you have any other questions or concerns!
-Sam
Thank you for sharing a screenshot. This is somewhat strange behavior. It appears like we have the WGS 84 globe but not textures, imagery, or topology. Are you currently using Cesium ion for this application? If so, I would start by ensuring that you have the correct access tokens set up in your development environment. Our CesiumJS Quickstart tutorial does a great job covering access tokens!
Looking forward to learning more!
-Sam
Thanks for the reply yes i have access token i will try it, can you please check this question Capture zoom out event actually i want to capture zoom event as soon as a zoom point is achieved then i have to changed the layer image
Great! Give that a try. I will get to your questions as soon as possible. There has been overwhelming inbound of forum posts recently, so your patience is appreciated
-Sam
