Hi I am building an application where i want the OSM as the default base layer instead of the bing Maps is there a way to do so. I have tried adding the code as mentioned as shown below
var osm = new Cesium.OpenStreetMapImageryProvider({
url : 'https://a.tile.openstreetmap.org/'
But it throws an error
“Uncaught TypeError: Cesium.OpenStreetMapImageryProvider is not a constructor”
Because of the reason i have to visualize the data every time a small change happens and i am nearly at the limit of 1000 bing sessions. Secondly i am doing this for my MS so i cant buy the cesium ion upgraded version
