Passing a uniform to primitive
I made a primitive using custom webgl code. I was able to render what I wanted with it, but I can’t figure out how to pass data to it in the form of a sampler2D uniform.
I am trying pass a large array to the vertex shader. Is there a way that I can do this by either encoding the data as an image or by using some other method to pass the data as a sampler2D uniform? I searched thru the forum but couldn’t find any examples.
Capture.png shows how I am making the uniform (with a dummy example of a 1-pixel image). Then I set drawCommand.uniformMap = this._uniformMap when the frame state is updated.
I can make triangles and animate them so I know the basic setup of the primitive is correct. But I get an error whenever I try to access a sampler2d uniform.
I can’t do this by using a material because I need the full vertex shader to fragment shader webgl pipeline to create an animation.
Cesium 1.5, Chrome, Ubuntu 16.04.
Thank you so much.
I figured it out. I needed to return the values in uniformMap as functions. There is a good example here:
