While in 2D polylineGeometry are not being rendered correctly at certain zoom levels. Occassionally the graphic appears to extend down towards the lower left corner of screen. In 3D it appears to render properly.
Once the globe appears click on the 2D (scene picker) button and zoom in/out slowly. At some zoom levels you will see the line exten down to the lower left corner of the screen.
var geomInst = null;
var linePoints = null;
var primitive = null;
var sceneModePicker = null;
var viewer = null;
viewer = new Cesium.CesiumWidget('cesiumContainer');
sceneModePicker = new Cesium.SceneModePicker('sceneButton', viewer.scene, 0);
linePoints = [-71.19881, 41.6785, 0,
-71.19994, 41.46332, 0,
-71.11713, 41.49306, 0,
-71.14121, 41.65527, 127,
-71.19881, 41.6785, 0];
geomInst = new Cesium.GeometryInstance({
geometry: new Cesium.PolylineGeometry({
positions: Cesium.Cartesian3.fromDegreesArrayHeights(linePoints),
width: 1.0,
vertexFormat: Cesium.PolylineColorAppearance.VERTEX_FORMAT,
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.RED)
primitive = new Cesium.Primitive({
geometryInstances: geomInst,
interleave : true,
appearance: new Cesium.PolylineColorAppearance()
viewer.scene.primitives.add(primitive);
The only thing that is a little different is that I am using the Cesium Widget and the Geometry API. I am using the widget for performance reasons I only need to deal with a large set of Geometries.
Cesium version 35, Windows 7, Chrome 59.0.3071.115
Thanks in advance
Jerrold Stoy
