I’m drawing polylines and adding points to them dynamically in a 2D map. At one area, the polylines overlay on top of eachother for a period of points. When zoomed in, the lines display as expected but when zooming past a certain level an artifact is displayed whose appearance keeps changing as the zoom finalizes (finishes updating the map). The artifact is most noticeable when using a line width greater than 1 (in the attachment a value of 5). Any ideas on what is causing this artifact or how to get rid of it?
My app is not available but I’ll attempt to create a test case to reproduce it on Monday.
It does happen in 2D, 3D, and Columbus views.
It happens in Chrome and Firefox on multiple computers and I believe that the drivers are up to date on at least one of them; which driver are you referring to?
That’s what I figured but I confirmed that on this laptop the video card driver is up to date.
I put together a sample in the sandcastle. I’m not seeing the same artifact but I am seeing a zoom issue which I think is likely similar to my original artifact issue. In this version, as you zoom (in particular on the Virginia end with differing points) you see flickering (maybe z-index fighting) and aliasing issues. Attached is a “saved” version from the sandcastle.
