Polylines penetrating the map surface
I try to load geojson (type MultiLineString), Via GeoJsonDataSource.load method.
the polylines that were created has penetrated the surface, I want them to stop at surface height.
start position should be above the ground and the end position on the ground.
I want to preserve the ‘3D behavior’ - when I change to globe view I could see the polylines’ height - so clamp to ground isn’t an option
I added the code below for reproduce in sandcastle:
viewer.dataSources.add(
    new Cesium.GeoJsonDataSource('test').load(**Here we load the geojson I added below**)
MultiLineString.geojson (105.4 KB)
here is a sandcastle example:
MultiLineString example.
(For those who understand the question and want to answer: This is the same as Polylines rendering below the map )
