We are developing a VR application and would love to be able to dynamically change certain values of the tileset like “Maximum Screen Space Error” and “Enable Frustum Culling” without the whole tileset reloading.
Our idea is when a user is flying around the globe or even in a city the Screen Space Error could be relatively high to increase performance while moving around, but when the user stops and lingers around I would like to increase the resolution of the tileset by dropping the Screen Space Error. This would allow the user to see much more detail in the tiles.
Currently the implementation of setting these values with their public setters calls RecreateTileset(), which makes the whole tileset start to load from scratch again, which is not ideal for what we are trying to do.
Is there any way to achieve what I’m trying to in the current version?
No, there’s no workaround for that currently. It wouldn’t be a huge code change, though, to make the setters for those properties instead update the equivalent parameter in the existing Tileset instance held on the C++ side, rather than recreating it. We’d welcome a pull request for that if you’re up for it.
Would that be a change to how the C++ is called on Cesium Unity side or a change to how the setters are set up on the Cesium Native side? Or both?
I don’t mind looking into the change and seeing what I can do. I will say my confidence in C# is higher than in C++ though I should be able to make my way around some simple changes in the C++ side.
It would likely require changes to both the C# and C++ code.
On the C# side, in all of the properties that can be changed without recreating the tileset, you’d just replace the call to RecreateTileset with a call to UpdateTilesetOptions. Then that UpdateTilesetOptions would be implemented in C++ to query the new values of the options from the Cesium3DTileset instance and assign them to the TilesetOptions instance on the native Tileset.
I then added this line to the Cesium3DTilesetImpl.h: void UpdateTilesetOptions(const DotNet::CesiumForUnity::Cesium3DTileset& tileset);
Then inside ConfigureReinterop.cs I added this line tileset.UpdateTilesetOptions();
And in the Cesium3DTileset.cs file I added this: public partial void UpdateTilesetOptions();
Then when returning to Unity to try and get Reinterop to rebuild the changes I get errors in the console NotImplementedException: The native implementation is missing so Update cannot be invoked. This may be caused by a missing call to CreateImplementation in one of your constructors, or it may be that the entire native implementation shared library is missing or out of date.
I feel like I’m missing some small step in the process but I for the life of me haven’t figured to what I’m missing. This dev flow is very new to me so I’m pretty sure it is something I’m doing wrong.
Also to note when I remove the line from ConfigureReinterop.cs the editor no longer throws errors and the tileset loads but obviously doesn’t have the changes I want to access.
So I ended up getting it to work the way I wanted to but it required a change on cesium-native side as well just the addition of the setOptions function in Tileset.cpp and the declaration in the header file.
Wondering if there is a way to set the options on the tileset without the need to add this function. I see that getOptions returns a pointer of the options object so I thought I could just change the values of that and it would work but sadly that did not work. So I just added this small function and called it with the new changed options object.
Getting the options from the tileset and then setting properties on it should work. In fact, if you have something like this working with your code change:
tileset.setOptions(newOptions);
Then it should work just as well with:
tileset.getOptions() = newOptions;
But setting individual properties is probably better. It might help to share your (non-working) code.
What I was doing prior to the setOptions() which is now replaced, was assuming that because options is set like so TilesetOptions options = this->_pTileset->getOptions(); that I didn’t need to “set” it back as I thought it was a reference to the real property and changes I made on that object would reflect onto the tileset. So the code just ended after setting all the options.value.
When maximumSimultaneousTileLoads is changed it causes all tiles to reload, but it makes no sense why changing that value would require reloading all tiles. Is there plans to fix this?
I read that the author has left the company or something similar, does that mean Cesium will no longer receive critical or necessary updates so issues like this will never be fixed?
The author of that PR never worked for Cesium, and the reason it hasn’t been merged was because they were not able to get permission from their company to contribute to the plugin.
Cesium for Unity is still actively maintained by the team at Cesium / Bentley Systems. We also love it when folks outside of Cesium contribute to the plugin! We do require that contributors sign a Contributor License Agreement, though, which simply affirms that the contributor owns the changes and/or has permission to contribute them.
Yes I believe that makes sense in a official capacity, except how do I disable tileset redraw when maximumSimultaneousTileLoads changes? Because it consumes a ton of extra bandwidth and completely prevents dynamically changing the number of tile loads, I would like to have dynamic quality setting.. But from what I am reading there is really no way Cesium owner will add this change. And now after a year of no activity it has become even more difficult to add this requested feature because a author somewhere did something similar, and that is the end of the story?
The previous author’s work has no bearing on our ability to add the feature. We or someone from the community just have to implement it independently, we can’t use the previous work.
It’s not currently a high priority for the team at Cesium, but it is a straightforward change for someone from the community to implement and hopefully contribute back.
Essentially, you need to change the code so that it doesn’t call RecreateTileset here:
And then you need to pass the value in to the C++ Tileset class’s getOptions(). One easy way would be to do it in this Tick method:
