primitive.remove
Hi
My Goal is the have BoxGeometry plot on the globe based on a file from a webserver. The next phase is to click and drill down on it. This is what I have done so far.
  1. I could retrieve the file which says what to plot from the webserver using jquery.
  2. Call the function [1] to create all the boxgeometryinstances I needed.
  3. Then call [2] to have it plotted on Globe.
  4. I have included the first three inside “setInterval” function which gets called every 5 seconds.
  5. When I try to remove the boxgeometry which is no longer required after 10 seconds I am unable to with primitive.remove, However primitive.removeAll() removes everything with a blink which I would like to avoid. I am wondering why primitive.remove of the first object won’t remove the bar plotted on the globe even when it say “True” for variable a in “var a = scene.primitives.remove(primitive[1]);”. I guess it might partly be due to the fact that I am reinitializing the primitive in function[2].
I have a question about primitive.remove.
[1]
function plotROD(lat, lon, height, id) {
    var dimensions = new Cesium.Cartesian3(100000.0, 100000.0, height);
    var positionOnEllipsoid = Cesium.Cartesian3.fromDegrees(lon, lat);
    var boxModelMatrix = Cesium.Matrix4.multiplyByTranslation(Cesium.Transforms.eastNorthUpToFixedFrame(positionOnEllipsoid),
        new Cesium.Cartesian3(0.0, 0.0, dimensions.z * 0.5));
    var boxGeometry = Cesium.BoxGeometry.fromDimensions({
                        vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT,
                        dimensions : dimensions });
    boxGeometryInstance.push(new Cesium.GeometryInstance({
                                geometry : boxGeometry,
                                modelMatrix : boxModelMatrix,
                                attributes : {color : Cesium.ColorGeometryInstanceAttribute.fromColor(
                                                        new Cesium.Color(1.0, 0.0, 0.0, 1)),},
[2]
for( pi=0; pi < boxGeometryInstance.length; pi++ ) {
        primitive[pi] = new Cesium.Primitive({
                        geometryInstances : boxGeometryInstance[pi],
                        appearance : new Cesium.PerInstanceColorAppearance({
                                        translucent : false,
                                        closed : true
            scene.primitives.add(primitive[pi]);
test.html (4.66 KB)
